Results 1 to 12 of 12
Thread: funny clutch sound
    84 VK 3.3 Converted to EFI
    Nov 2005
    Default funny clutch sound
    ok peoples here goes every now and then when releasing it makes i funny wierd rubbing noise anyone had a similier prob and know what it could be....and before i get asked the clutch cable,bearing,pressure plate are about 4 months old...
    cheers
    Mods-Conversion
    4 Speed Manual conversion,
    VB Dash,
    EFI conversion,
    Straight Gas,
    VH seats and door trims,
    5" tacho,
    POD Filter,
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Clutch fluid still pumping? maybe something needs grease'n
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    doesn't the vk use a cable clutch ?
    if you rest your foot on the clutch enough till it just takes up does it make a noise then .... has it been making the noise since it was installed or just recently started to make the noise ?
    VX S Series 2
    Jul 2005
    Coffs Harbour NSW
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Throw out bearing cactus?
    VK wagon
    Aug 2006
    NZ
    rubbing sound is a bit vague.. but could be anything from pedal being too dry, to loose clutch plates. Try to locate where the sound is coming from, inside/outside and go from there.
    Nov 2005
    seems to only make noise every so often when i take off releasing clutch i think i might be the cylinder that goes into wall
    Mods-Conversion
    VB Dash,
    EFI conversion,
    Straight Gas,
    5" tacho,
    POD Filter,
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Goon View Post
    The old Commos all had a cable driven clutch, not a hydraulic one. When did the hydraulic clutches come in? VN Commos?
    May 2004
    Tenambit, NSW.
    im pretty sure all the vn-vs use cable aswell, not sure about vt onwards but i know my vz ute has hydraulic clutch.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    VB-VK use cable, the VL uses hydraulic clutch, then VN-Series II VS use cable. I think late VS's use a getrag gearbox which uses a hydraulic clutch
    VK wagon
    Aug 2006
    NZ
    vl's were the first with hydro clutches me thinks too
  1. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  2. Funny Sound
    By parkerst in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2007, 10:51 PM
  3. Funny clacking sound in 2000 VT
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:07 PM
  4. Funny sound - 98 VT. Anyone heard of this?
    By gyp23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2006, 01:13 AM
  5. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
