Results 1 to 3 of 3
Thread: cam size
    VH wagon
    Aug 2005
    Default cam size
    Hi every one how do you measure up a cam. I have been given a new cam and have been told it was a bigger cam than standard. I can get some photos next week if that will help.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    It takes alot of work to measure a cam it really needs to be installed then you use a dial indicator to measure the lift, as you rotat it you can measure the valve open & close durations and obe offset.
    Most cams will have brand and serial number stamped into the back of them. If yours does contact the supplier quote the serial number and they will beable to send you a cam grind sheet.
    cheers
    Scott
    VH wagon
    Aug 2005
    Thanks for that I will have a look at it when I go and pick it up.
  1. What size amp for 6x9 and what size amp for subs
    By Infanti in forum Car Audio
    Last Post: 12-10-2006, 07:28 PM
  2. wot size amp???
    By silver88vl in forum Car Audio
    Last Post: 19-09-2006, 07:17 PM
  3. xf tb, which size?
    By hosedogg in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-09-2006, 06:44 PM
  4. MAX Mag size on VP?
    By pete_pumpkin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 01:57 AM
  5. What size amp?
    By SSGEN-3 in forum Car Audio
    Last Post: 26-08-2005, 06:59 PM
