Results 1 to 5 of 5
Thread: Lead Replacement Question.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Lead Replacement Questions.
    Hey All
    I have 2 questiosn about using lead replacement lube fo fuel, # 1i use the nylon stuff and its great, but is there a point where u can only put so much in a with the amount of fuel in the tank?
    I sort the amount out easy witthe bigger bottles by the cap, but with the squeeze mini bottles sometimes its to much
    2# the mini bottles treats 50 liter or so, if i planned to travel over 400 - 600k, would it be best to use 2 mini bottles per a tank instead of one? <-- thinking about engine heat with this question plus time it takes to travel and if the car gets stop time "refuel or 20min break" or not.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I think you mean Nulon? Not Nylon?
    There would be no benefit in adding more. It would be just burning money. Just follow the recommended and you shouldn't have any problem.
    The whole purpose is obviously so your valves don't burn out as the stuff acts like old Super and lubes your valves and seats. Without it, after a long time, well it depends, it wouldn't root your engine in the short term but your valves would slowly burn out after an extended period without adding it.
    Have you considered maybe getting a reco head and a nice cam? Your motor would be improved heaps more and you could run unleaded fuel fine. As for the additive, look at buying big bottles instead of small ones. Surely the savings would show down the track.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks mate
    As for engine parts, savin up for next year OTHER car stuff first
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I should also add. You said you were worried about the heat and you were thinking about adding extra. As far as car motors are concerned, they always run better when warm-hot. If you know what it runs like on a cold morning, the difference when it's warm is a lot.
    Goon's Avatar
    Feb 2006
    GC. QLD
    True that mate
  1. Front Window Replacement Question.
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-09-2007, 07:36 AM
  2. Power lead
    By vs_clubby in forum Car Audio
    Last Post: 01-05-2007, 10:29 AM
  3. Lead Kits for LPG ?
    By DF_Media in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2006, 12:04 AM
  4. Where does this lead??
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 11:42 PM
  5. lead or unleaded?
    By Bush VB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-08-2005, 08:30 PM
