Results 1 to 6 of 6
Thread: Spigot bush for V8
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Spigot bush for V8
    Could someone please give me a quickie how-to on replacing the spigot bush in my 308 V8 for a M20 manual conversion?
    Thanks.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Easiest way to get the old spigot bush out is to find a bolt or steel rod that is a neat fit in the hole in the spigot bush. Fill the hole with grease then hit the bolt in the hole with a hammer. This forces grease behind the bush to push it out. when the bolt hits the crank pull it out and put more grease in then hit the bolt in again. Keep repeating this until the bush is out then wipe the grease out of the hole when finished.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Thanks.
    I don't know what the things look like. The only thing I know is they are pressed into the crank or something.
    Apr 2006
    Mt Gambier SA
    Default Spigot bush
    This is a photo of a Blue 202 crank with a manual spigot bush fitted. Manual trans use a brass bush that fits flush with the crank like in the photo and the auto bush is made of steel and has a tapered bit that sticks out a bit for the torque converter to centre on. The V8 should have the same size hole in the middle as the 6 but the outer diameter is a bit bigger. The spigot bush is the bit in the centre of the crankshaft. You can tap a new bush in with a hammer, but be carefull because the brass bush can be easily dented or chipped. Its best to use a bit of wood as a punch that you hit with a hammer to hit the bush in
    Last edited by Tree cutter; 04-11-2006 at 06:28 PM. Reason: added extra imformation
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Thanks a lot for that.
    Can you buy the bush from any spare parts places? What are they usually worth?
    Cheers.
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Quote Originally Posted by Slim View Post
    Cheers.
    Yes they are, should't be more than about ten bucks. Another method of removing them is to get a tap that uses the same drill size as what the bore of the bush is. Tap the hole all the way to the bottom, and then keep on tapping, the bush should screw out on the tap.
  1. Where can i get a spigot bush for a 202 blue?
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2007, 03:41 PM
  2. no idea about spigot bearing
    By michaelrocks36 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2006, 06:24 PM
  3. spigot bearing?
    By vrbenno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 12:22 AM
  4. spigot bush vl commodore
    By alarna in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-07-2005, 04:41 PM
  5. VP Auto to Manual - Spigot Bush
    By Tadeusz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2005, 07:39 AM
