Hello,
I have a VH commodore which stalls when warm and I cannot re start until if cools down. Runs for about 15minutes then conks out.I have just replaced the ignition module plugs and leads. It also has just has a reco carby.Could it be the coil, how do i test for this?
many thanks
this may sound odd, it's been know to happen just once or twice, but.............
do you have the standard/an old exhaust still on it? if so, hop under your car and give the muffler a tap, if it sounds solid, it may be clogged.
i know, sounds odd and it is a rare occurance but if all else fails, it can't hurt to check
Has it got plenty of oil in the motor and water in the radiator?
