Results 1 to 9 of 9
Thread: Carby Screw Question.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Carby Screw Question.
    Hey All
    Is the retainer screw meant to have a hole? on its side in the indint place for a scerwdriver. My screw is only plastic... I push the pump and notice fuel coming out of the retainer screw hole, but it may lead to the jet or something when it shoots out?
    Thanks.
    [EDIT] This screw is located under the top half of the carby.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Goon's Avatar
    Feb 2006
    GC. QLD
    Is there a good gasket goo used with fuel? i really need to block this hole so it stops flooding my carby
    Everytime i push the pump fuel shots out of this screw...
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    If its only plastic superglue should work but before you do, post a pic of the screw im having trouble working out where you mean/which screw.
    cheers
    Scott
    Goon's Avatar
    Feb 2006
    GC. QLD
    The top half of the carby off, top piece.
    Float camber, and pump rod, right of the pump rod about 10 -15 cm is the retainer screw, it's meant to have a bearing under it, which i was trying to install from the carby-kit..
    I push on the pump rod and a notice fuel squirt out of the hole on the retainer screw, which i must of made while trying to remove it.
    Thanks.
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    take a photo dude, it makes it easier to figure out what you're on about...
    No wah to that!
    Never late with ROB308...
    Goon's Avatar
    Feb 2006
    GC. QLD
    Here's a pic, its no my real carby as i need my car to still go for emergencys..
    She runs but if i come to a complete stop under 20k, shes chokes on this extra fuel comig out from the retainer screw.
    http://forums.justcommodores.com.au/...1&d=1163033268
    Attached Thumbnails Attached Thumbnails Carby Screw Question.-carbyfixitpic.jpg
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    if i remember right, i think thats supposed to have a hole in it dude...
    No wah to that!
    Goon's Avatar
    Feb 2006
    GC. QLD
    That's what i thought...
    But my timings right, so its not that, same for air and mixtres, shes all good apart from this commplete stop, if i can slow down easy without using brakes she wont do it, but if i have to...under 20k
    I'm sure my float is set right , does it have to be flat with the bowl? the float itself, the arm doesnt look like it has been bent to 6.8 before, would it be an idea to try that out ? What should i use to bend the arm it with?
    How muh fuel should be in the bowl if i take the carby top off?
    I just wanna get the job done right this time, spent last 2 days in the hot sun with her plus a day of roadtest
    [EDIT] I'll work on this float and see how things work out
    Goon's Avatar
    Feb 2006
    GC. QLD
    Well the carby! that went back togthere the 2nd time around i replaced the valve in the float bowl and used my GM float needle instead of the one giving to me in the kit that was in it before..
    Did a minor tune up and set the choke again and shes working great.
    No issues so far
  1. Screw with your mates
    By v8oz in forum Jokes/Humour
    Last Post: 11-10-2007, 01:13 PM
  2. Slow idle screw.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-02-2007, 04:50 PM
  3. Throttle Stop Screw
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-09-2006, 01:43 AM
  4. why does the MAN screw us???
    By MikeVXSS in forum The Pub
    Last Post: 13-04-2006, 06:15 PM
  5. screw in studs wanted
    By krawczuk in forum Swap / Wanted to Buy / Trade
    Last Post: 11-04-2005, 06:32 PM
