Results 1 to 17 of 17
Thread: 350 holley install on a 202 black
    VN/VT
    Sep 2005
    SA
    Default 350 holley install on a 202 black
    hey guys im about to install a 350 holley on my black 202 and i am just wondering if any one has a how 2 guide some were, i have the adpater plate for the standard manifold and i was also wondering if there was anything eles i need.
    cheers, nick
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    You'll Need To Make Up A Bracket To Hold The Accel Cable, But Other Than That, Theres Not Much Else You'll Need... To Install, Its Fairly Straight Forward...
    No wah to that!
    Never late with ROB308...
    VN/VT
    Sep 2005
    SA
    Quote Originally Posted by atrail308 View Post
    can i buy these brackets? or do i have 2 make one
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    may be able to buy it, but pretty easy to make, either fabricate an old one to fit or start from scratch, just work out where your cable need to be held, then go from there...
    No wah to that!
    VH V8
    Sep 2005
    dont forget to put gaskets or gasket glue on the adapter plate and carby and manifold.
    Have a good one
    .............Vincent.............
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    you can go without the glue on the carb and adapter plate, i've always fitted them dry and never had a problem...
    No wah to that!
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    I would smear a small amount of glue on the gasket surfaces. When i did mine i had to get a v8 cable as the 6 was couple inches too short but i was using an after market manifold. You can buy the brackets for about $15 Redline are the only company iv seen that make the brackets im pretty sure their the only ones that make the adapter plates to. If you need a hand let me know. Iv done it a few times now. Its pretty straight forward but it might take a while to get it running the way you want.
    VN/VT
    Sep 2005
    SA
    Quote Originally Posted by Dan355 View Post
    yeh i think i need a v8 cable do you know what they are worth? and how do i go about finding the redline bracket? you reckon out laws in town might have one?
    VS Series III ute 5.0M and VL Berlina Turbo Wagon
    Sep 2006
    Putting a holley on the stock manifold with an adaptor plate doesn't acheive much except worse fuel economy. The horrible old stromberg is actually capable of reasonable power levels but the air-cleaners are hopeless and they're stiffled by pollution controls. I would just fit a better air-cleaner and block off all the polution control hoses , block off the manifold heater lines
    and fit a nice big 'Holley equipped' sticker on the back window.
    If you do fit the holley I would still block off the heater lines to the manifold.
    VN/VT
    Sep 2005
    SA
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    try outlaws or pro action, if niether of those have it, you may end up having to make one, which im sure a lot of people have done...
    Like 5Litre said, your prob better off stickin with the std 2bbl rochy (strommies stopped on the VB)...
    No wah to that!
    Dan355's Avatar
    May 2006
    My car ran fine with the 350 holley but it is very important to get the carb built/tuned for a six. Nearly everyone i talk to just wack them on and adjust the mixtures. Now thats why people are against the whole holley conversion because they have no clue. Any speedshop or carb specialist will have the bracket. I have one here but im keeping it A redline torker11 manifold would be a good idea though. That would enable you to lose most of those vacume hoses. Looks alot better to.
    VN/VT
    Sep 2005
    SA
    is there any benifit in using all of the vacum hoses?
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    Quote Originally Posted by sirVkcalais View Post
    No, they're just for emissions, i've got one on my whole engine...
    No wah to that!
  15. #15
    Dan355's Avatar
    May 2006
    Yea its just for emissions. I think you only need the booster vacume, pcv (i think thats what it called)....the hose from rocker cover to inlet manifold, with the valve. And all hoses to and from carbon canister. I passed regency with just that but that was with a blue motor in a vh.
  16. #16
    VN/VT
    Sep 2005
    SA
    cheers guys you have been very helpful ill let you know how it all turns out
  17. #17
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    I gotta 350 Holley here aswell I'm putting on a worked black 202 with a Mega Tork stage 1 Cam, Pacemaker Extractors, new Pistons & Rods.I had the head shaved & dun up 4 ULP.To complete the top I'm going for rollers.Just the H/V Oil Pump 2 go & it's sweet.When the Boss(Her)gives me pocket money..
    Tony 308vkcalais:
  1. 350 Holley to 202 Black
    By Rosco666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-06-2010, 06:12 PM
  2. Replies: 73
    Last Post: 04-02-2009, 04:54 PM
  3. WANTED: Adapter plate for a black 202 manifold to fit a 350 Holley
    By V-ahhh in forum Swap / Wanted to Buy / Trade
    Last Post: 02-09-2006, 09:25 AM
  4. F/S 350cmf Holley with adapter plate for black 202
    By RevHead1313 in forum Parts And Other Items For Sale
    Last Post: 05-08-2006, 06:33 PM
  5. 202 black - varajet, webber, holley or efi + other questions
    By TheWombatDriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-04-2006, 04:11 PM
