Results 1 to 6 of 6
Thread: wiring harness
    vk commodore
    Apr 2006
    Default wiring harness
    hey
    i was wondering if anyone knows if it is possible to buy new or 2nd hand under bonnet wiring harness for a 308 vk
    cheers
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Castlemaine Rod Shop might have brand new engine bay loom for a VK 308. Most auto elecys can make up a new loom, at a cost
    vk commodore
    Apr 2006
    have u got any idea of what that cost could be? wouldnt be cheap would it?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Sorry don't know the cost but i reckon its not that cheap. The only probblem about 2nd hand wire loom is that it will be aleast 20 years old, some wires maybe brittle.
    You might have to look and ask around some wrecking joints.
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Bah, fixing your own wiring harnesses is fun I reckon
    Maybe that's just because I'm a bit better with a soldering iron in my hand than a spanner...
    the lightning
    Jun 2005
    under the Southern Cross
    If you're clever and have the time, you could go to the wreckers and get the ENTIRE loom from a VK or (even a later car as you'll get even more wire), strip all the electrical tape off it carefully and lay it out, then you'll need to copy your existing loom (and perhaps even improve it if you can see things with the existing loom that you arent happy with and would do differently).
    I'm in the process of doing parts of mine where the wires are heat perished etc. buy yourself a good quality crimper and a fancy wire stripper that the auto elecs use (expect to pay around $25-$30 for each), if your in melbourne Jay-Dee Autocable in Bayswater have them, if you're doing a lot of auto electronics then they'll save you a lot of time and trouble (Ive got some and use em all the time). to do it yourself could cost up like this i guess;
    complete loom from a VK or later $20-$40 (sounds a lot but you try buying that much wire from dick smiths or tandys in all the colours you'll need and see what it costs you!!)
    Toledo Wire Cutter; around $25-30
    Bellanco Super Crimp III; around $25-30 www.bellanco.com.au
    you'll need these to replace the harnesses
    harnesses; expect to spend somewhere between $20-$100 i guess depending on how many harnesses and looms you tackle.
    or you can try and buy one but I have no idea on how much they would cost.
  1. Wiring Harness
    By SinisterVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-05-2007, 11:28 AM
  2. Vs Wiring Harness
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 03:45 PM
  3. VT wiring harness??
    By dbun in forum Car Audio
    Last Post: 03-08-2006, 10:30 AM
  4. VR wiring Harness
    By dutche in forum Electrical Wiring / Questions
    Last Post: 13-04-2005, 02:59 PM
  5. Wiring Harness Guy
    By vkberlina in forum Electrical Wiring / Questions
    Last Post: 24-03-2004, 12:32 AM
