Results 1 to 9 of 9
Thread: Really need your help to find gasket sheets
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Really need your help to find gasket sheets
    Hi there,
    I am trying to find metallised gasket paper for making your own gaskets to suit exhaust flanges etc. I found this site http://www.gimmecarparts.com.au/sear...ategory=TP1144 I think it's a sponsor of JC.
    Could anyone please make sense of these products:
    Gasket Material ACL BLANK SHEET EXTRACTOR 1.5x305x
    Gasket Material ACL BLANK SHEET EXTRACTOR 1.5x750x
    Is this the stuff I want? What does 305x and 750x mean?
    Cheers,
    Craig.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    305x=305mm. This one here would be for Holden V8 extractor gaskets.
    750x=750mm. This here is for the old Holden inline 6 banger extractor gaskets.
    The 1.5 would be out thick they are, about the standard
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    So the term 'extractor gasket' means the metal type ones and not the paper only ones?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well i'm sure they can come in both.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    The extractors gasket i got is a metal type, if that helps
    I couldnt' see paper lasting that long if you tried that..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I have got an order in at Autobarn. $12 for a 750x125 sheet. I hope the extractor gasket they are selling me is the metal type. If not, I will need to use it anyway I guess.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Autobarn stuffed up and now I have an order through Burson. I was going to order the gasket sheet through Gimme car parts and they want $10.45 postage! Get real. I can get it for $9 cheaper at Burson.
    1992 HSV SENATOR 5000i
    Apr 2006
    N/W NSW
    Go to your local muffler shop & they will give you as much as you need cheap as they buy it in bulk.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I think I am going to get better flanges and proper gaskets.
    This gasket paper is damn hard to cut and I have screwed it up bad. I need a laser cutting machine.
  1. Dyno Sheets
    By AirStrike in forum Dyno Figures
    Last Post: 02-05-2012, 02:33 PM
  2. Build sheets under carpet
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2012, 07:34 PM
  3. gasket tip
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2010, 09:37 PM
  4. Dyno Sheets
    By kilmo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 11:36 AM
  5. VRS Gasket Set?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2006, 08:02 PM
