on the wiring loom to the engine (V8) theres a 21pin harness (the big one) with the ignition wire and some wires to the oil/temp senders etc.
just before this harness I have a white female harness with 2 pins/wires red and yellow that goes nowhere.
just after the 21pin harness theres a 2pin female harness that goes nowhere and a 4pin male harness that has a couple of wires in series with the harness just mentioned. I traced the wire in series to the fast idle solenoid, then a switch on the back of the A/C compressor and as well as some 2 pin plug thats part of something for the emmision control which is long gone.
can anyone shed any light on the remaining wires/plugs? are they something for the EFI 202s perhaps? or the cruise control?
once again any enlightenment is appreciated.
[QUOTE=Cane_It;452910]
[QUOTE]
From memory the cruise control wires are red and green. Sorry I can't help on the rest, but I for sure is going to be going over my wiring AGAIN with a magnifying glass very soon and fixing the lot up.
