Results 1 to 11 of 11
Thread: Now my car is running like a barge
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Now my car is running like a barge
    Yep, I am a victim. My car for the past few days has been running like a complete barge. There is heaps of flat spots and has stalled once. It's undriveable at the moment.
    I just chucked 30 litres of Vortex in at the servo. It had about 10 litres in it, so it probably has around 40 odd litres in the tank.
    When I drive, there is heaps of flat spots like major cylinder miss. The spark plug and leads are fine. Doesn't need to be timed as it's fine. I am not sure whether it's a vacuum leak or my carb pump is stuffed or what. It does the same thing on gas. Maybe it's got a leak.
    Any suggestions?
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    When in park, it idles good. Pressing the pedal and revving it when in park sounds beautiful. As soon as I put it in drive and drive off with load on the motor, it runs terrible.
    I am beginning to think it isn't a vacuum leak because it would show up when in park and probably a lot worse.
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    It has to be an ignition issue if it does it on both fuels. If it was a vac leak it shouldnt idle properly.
    Im not a complete idiot, some parts are still on backorder!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    The gas is unfortuneately a seperate issue. The gas played up and crapped it 2 weeks ago. The problem was the converter likely being glogged.
    Then the car was put on petrol and has been running nice for 2 weeks until today the above crap has happened, so the two are seperate problems. I can fix the converter, but the petrol problem has got me stumped.
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    if its vac, it would work on petrol and gas, so that wont narrow it down from a fuel issue or igntion issue, but to me it sounds like you'r carby is playing up, if you quickly stab it in park, will it hesitate???
    have a quick look through this rochy diagnostic i found when i was having trouble with mine, it might help you out a bit...
    http://www.florida4x4.com/tech/quadrajet/qjtshoot.pdf
    No wah to that!
    Never late with ROB308...
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    When chucked in park, it is ok. The barge is fine when not moving. I have booked into the mechanic in the morning. Hopefully it's a simple crap problem that can be fixed without major time involved. If I had 250 bucks, I'd go and get a reco one. But I'm broke.
    Thanks for that carb link. It is very good, but as it says, there could be a million things wrong with my carb whether it be a bad float or needles or anything.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I am having a gut feeling now.
    For some reason I am thinking it's an ignition problem more than a carb problem. When I took the filter housing off, I pumped the throttle lever and saw that the fuel was spraying out of the jets fine.
    It brings back about the supposed ignition module problem I thought I might have had. Basically 2 weeks ago I put it on petrol after I thought my gas converter was dirty. Now the same thing has happened but this time petrol. I am wondering whether it might be spark related because when I saw the jets spraying out fuel well, it seems to be more ignition likely.
    Hopefully the mechs can find the problem and I can get a replacement part and fix it. It could be a distributor/module problem or the coil packing up. At the moment it sucks because I have got very little spare parts sitting around as I have only had my car for 11 months. A spare dissy would be handy and a coil. Time will tell I guess.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Got my car back. They think the carb is being starved of fuel. I will need to get my cousin to pull the carb off and have a look. The fuel part of the carb where it manages it must be at fault. I have a couple of spare carbs for parts. Just need to get another gas converter so I can at least run it on gas which is coming in a couple of days.
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Thanks. Not having much luck lately. T-bone a jerk, then my gas dies and now my fuel. Will be all sorted very soon.
  1. not running
    By icwoodsy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2007, 07:29 PM
  2. Replies: 7
    Last Post: 10-05-2007, 03:14 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. 85 VK P/S A/C Gas..... Not running
    By figjamidhVK8t4 in forum Parts And Other Items For Sale
    Last Post: 08-07-2006, 01:09 PM
  5. v6 only running on 5
    By vnrock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2005, 01:58 AM
