Results 1 to 14 of 14
Thread: vacuum gauge stoped working
    VN/VT
    Sep 2005
    SA
    Default vacuum gauge stoped working
    hey all this afternoon my vacuum gauge stopped working, so i was wondering wat makes it work?? like is there a wire on the coil like the tacho use's or is there a tube that has fallen of?
    cheers, nick
    VS Commodore Omega
    Apr 2005
    the lightning
    Jun 2005
    under the Southern Cross
    check and replace the tube would be the first step and make sure it hasnt been kinked shut or anything, failing that look for any obstructions in the back of the gauge, if theres nothing obvious and it still doesnt work then its a trip to the wreckers...
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by Juzza View Post
    I believe it's a tube!
    You believe is correct. I happen to take a vacuum gauge out in my VC, put in a tacho.
    I agree what Cane_It has said.
    SiLeNt-SoN's Avatar
    SiLeNt-SoN is offline 2000 WH Statesman
    2000 model WH statesman
    Sep 2006
    Hey, i thought while on topic id ask a question....
    my vacume gauge as in the gauge next to the speedo on mine is backwards, as when i excellerate the needle heads towards economy, and when my foots off the excellerator it heads towards power???
    if anyone has seen this before or even had the problem can u let me know on how this is fixed?
    thanks!
    WH STATESMAN
    1990-VN
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    That sounds like a vacuum leak.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by SiLeNt-SoN View Post
    thanks!
    I havent got mine to go to power before mate, only on a real shiat idle..
    Your gauge sounds off, or something isnt working right.
    My vaccum line for that gauge on my ride comes from the right hand side manifold valve into the wall behind my dash area, just a tip.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VN/VT
    Sep 2005
    SA
    VN/VT
    Sep 2005
    SA
    well i just checked and everything looks like its were it should be, im wondering if there is a fuse or a wire that has come loose?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    There isn't a wire or fuse for the vac eco gauge at all. The hose should be a real tight fit on the gauge and on the vacuum tree on the manifold,
    VN/VT
    Sep 2005
    SA
    ahright maybe its not tight enough behind the dash but it looked ok then.. do they just stop working sometimes? and just have 2 buy a new 1
    VS Commodore Omega
    Apr 2005
    I agree with Damien,
    If it looks fine at the dash it could maybe have come loose on the manifold, or you possibly have blown the gasket on the manifold (this would cause the reading to not work due to lack of pressure wouldn't it?)
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    ^^ Yep mate, spot on.
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    pull the hose off and start ya car and see if it is sucking (it will be really strong so don't put ya finger on the end of it lol) and if its working fine then get one of your big mates (or a hooker lol ) over and tell him to suck on the end of it and see if its working.
  1. this is weird...odometre stoped working but..
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2007, 08:56 PM
  2. airflow controller not working - vacuum cluster problem?
    By catalyst55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 01:18 PM
  3. vacuum Gauge
    By sexypete in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-03-2006, 12:03 PM
  4. Vacuum gauge
    By Dogmeat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-07-2005, 11:47 AM
  5. vacuum gauge not working
    By kooloo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-07-2005, 01:30 AM
