does any 1 know how hard it would be to put a vn dash into a vc
youd probly get more help if this was moved to the vc or maybe even vn section of the forums
~~Nic~ says:
yeah feel dick tho
I dont know how easy that would be. I have seen an EL XR8 dash and motor transplanted into an XY/XW falcon many years ago. Keep in mind that a VN is 50-60mm wider than a VC.
JBonD says:
not well at top end, as its a bit hard to go full load in 3 or 4th on a quiet street in dandenong @ 200kphCraig304 says:
quiet? whats that mean?
ive seen a vs dash in a kingswood so anything possible with money and time...
We got rep back, yaaay!
A kingswood is also a bit wider than a commodore but, if there's enough room between the pillars then you shouldn't have a problem, otherwise there may be some modification involved!
JBonD says:
