Results 1 to 5 of 5
Thread: HELP...! botom end knocking???
    vasrox is offline every bolt has a nut.....
    VH/SLE 308
    Jun 2005
    Default HELP...! botom end knocking???
    I have recently posted a thread about installing a VK EFI in a VH but I failed to mention the why...
    I have a 3.3 black motor that has had some work done on it in the past. Apparently due to the modifications I needed to get a speacial disributor but I could never afford it. Since then ive always had problems with timing and wasting fuel. Anyway a few days ago the bottom end started knocking while idling. But when I give it a little gas the knocking vanishes?
    Is this my bearings or timing or something else?
    ggggggrrrrrrrr.....!
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    oil pressure by the sounds of it. but have you got a timing light??? worth a quick check to see if its timed right
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Its hard to say what it is unless we can actually hear the noise. It could be big end bearings, but the oil pressure light would be on if they were gone. Cracked pistons will also knock when idling or it could be a noisy alloy timing gear if one is fitted
    VH/SLE 308
    Jun 2005
    I was previously asked if i had low oil pressure. When the car is in park there is no knocking but when i put in drive it knocks at around 13psi. Could this be the driveline, mabey the torque converter? It sounds like something is making it slugish...
    Apr 2006
    Mt Gambier SA
    I would say at a guess that it is the timing gear knocking, because when you put it in drive the revs drop a little and the engine will run a bit rougher so any backlash in the timing gears can be heard. She might just need a bit of a tune up so the revs don't drop down so low in drive. I have seen heaps of blue and black motors run rough because the plug gaps are too wide,should be 38 thou and i have seen them still running with 80 thou gaps. Set your timing to 6 Deg and check the idle mixture, then hopefully it will idle smoother and the knock will be gone. Your oil pressure seems OK to me.
  1. Vk Knocking
    By VK6CYL in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2007, 08:08 PM
