Results 1 to 10 of 10
Thread: starting issues..
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    Default starting issues..
    ok my car just stopped the other day i filled up with gas and went to drive out of the servo and my car just conked out...
    I have spark and fuel getting to the chamber...
    What other problems could there be?
    Oh i had a blown ignition fuse as well if that helps
    and do VK's have a crank angle sensor?
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    I'm guessing it's a carby one?
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    carby got an overhaul about 1 year ago...
    so you wouldn't think it could be that
    VS Commodore Omega
    Apr 2005
    There's no crank angle sensor, the computer gets all its timing info from the coil negative terminal of the ignition
    EDIT: Just realised it's a carby not an EFI.. check your choke.. also could still be the carby.. could also be severe warping of the inlet/exhaust manifolds but it should still start, just idle poorly..
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Put a timing light on it to see if the timing is moving all over the place.If the timing is moving then the EST module is the problem.
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    Apr 2006
    Mt Gambier SA
    Is the rotor button turning in the distributor. If its not turning you might have stripped a timing gear.
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    timing gears usually strip when they're under load i think.. were you taking off pretty fast, your car cut out and you hear a whirring sound?
    and if the car will just crank over but not start it's probably your timing gear
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    hmmm... i have heard a whirling sounds, and yes it does crank over. But i didn't take off fast :S
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    When I broke the plastic gear on the bottom of the dizzy my car was doing stuff all. I drove it into the position it was sitting in until oneday when I tried starting it and no go......I wasn't happy coz it was gonna be the last run b4 I pulled everything to bits. Just gonna get a metal gear to chuck on it when I put it back 2gether.
  1. VR starting issues
    By wylde_VR5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2011, 03:00 AM
  2. Vn Ss Starting Issues
    By Jazack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 10:12 PM
  3. Starting issues
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2007, 01:56 PM
  4. VS V6 Starting Issues
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2006, 06:35 PM
  5. VP Starting Issues!!
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2005, 12:08 PM
