Results 1 to 3 of 3
Thread: Need help with Transmission Selection
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    Default Need help with Transmission Selection
    I am currently putting together a V6 (VR) engine. Forcast output will be around 200 to 220kw.
    I am fitting this into a VL body. (Sorry if you think that I should be in the VL threads but I know that there are a few in here that have put cars together).
    I was wondering if any of you have advise on a transmission that is not only strong enough but have the right gear ratio to get the most out of the V6 and last but not least affordable.
    Thinking of 3.08:1 or 3.7:1 diff gears
    Any help would be appreciated.
    Kain
    the lightning
    Jun 2005
    under the Southern Cross
    if the TH700 fits use it, you'll have the overdrive for some kind of fuel ecomony with those gears in the back, theyre strong boxes and you'll still have fun off the lights with 3 gears before overdrive...
    I wish i had've done that with my 5L. but ive got a tri pattern block and a tri behind it and 3.08 gears... if i had my chance again i would do what ive suggetsed above, a friend did this with a WB ute and loves it.
    Apr 2006
    Bathurst NSW
    Quote Originally Posted by Cane_It View Post
    Thats interesting. I hadn't considered an auto. I'll look into it.
    Thanks for your suggestion.
    Kain
  1. amp selection
    By clyde in forum Car Audio
    Last Post: 07-11-2007, 06:29 PM
  2. help need with rotor selection
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-11-2006, 12:56 AM
  3. Extractor selection ?
    By Michelson4301 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 09:44 AM
  4. Cam selection
    By hotvrv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 04:29 AM
  5. Amp selection with 2 6x9s and a sub?
    By DavidPartay in forum Car Audio
    Last Post: 24-05-2005, 12:37 PM
