Results 1 to 9 of 9
Thread: Engine Transplant
    VX SS
    Dec 2006
    Default Engine Transplant
    Hello, i am new to this Forum, however i have a VC 308, heavily modified, however i had a alot of trouble trying to get it on the road. i had done an engine transplant from 6 auto - v8 man, roadworhty was passed however ran into some trouble with vic roads.
    vic roads wants a Engineers report.
    so the rung around begun, after ringing numerouse engineers they have given me the run around, IE: $1200 for the engineers, or get a report from holden on the originial specs and etc... on the car and types of engines it had came out with.
    rung up holden and dealerships, soundin like an idiot, got nowhere, and 1 person claimed he never heard of a VC commodore.
    i understand the fact that i need an engineers report, IE: brakes and suspension. i have been report to the OMVTS (organised motor vehicle theft squad) and was all cleared, some #@$%head at vic roads said my engine number was false.
    vic roads will not let me have my car on the road until i produce a engineer's report.
    If anyone has come accross this situation or has any advice can you please help me, or point me into the write direction so i can get the ball rolling.
    __________________
    There are three ways of doing things... the wright way the wrong way and the Max Powers way
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Well what is the engine number prefix, IE is it VT4***** or QT4****?.
    VK Se2 V6
    Sep 2003
    Country South.Australia
    the lightning
    Jun 2005
    under the Southern Cross
    sounds like they're being wankers, its not like your trying to put a chev in it. I would think a RWC would be enough for such an upgrade?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Maybe they want a report casue the plates arn't the same? from 6 to 8 u changed it? Thats why they might need the report.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    If the 308 you put in is a red motor then you will have to prove that it can pass emissions test. The VC had a blue motor with tougher emission standards. V8 commodores had a one inch bore in the brake master cylinder to give a firmer pedal than the 6cyl which had 15/16 bore. Not sure about the front sway bar but i think the V8 could be thicker also.
    VX SS
    Dec 2006
    sorry guys, went to phillip island for the V8's just got back.
    the front end springs, bushes etc.... are all new, aswell as tie rod ends and ball joints. the whole brake system has v8 calipers, and booster v8, also master cylinder is 1inch. with the emission standards i can have the red red motor in it, as long as it reatins the minimal basic setup for emmision requirements, motor is from same era.
    with the engine number the stamping where uneven, which landed me in this trouble in the first place, i had that checked out way back with the OMVTS, they had i dentified it with a 6cyl body shell and reqwuired for me to get a engineers.
    but that raises the question y?? all has passed r/w tests
    apart from being on hold with the, useless, vic roads, they check and check and check...... then after 1 1/2 hrs later, you need a engineers cert..
    VX SS
    Dec 2006
    Quote Originally Posted by Goon View Post
    compliance plates do register the car as 6 cyl.
    thats what they had caught onto and refused my registration.
    VX SS
    Dec 2006
    Quote Originally Posted by SL/ENUT View Post
    VT4****
    what really triggered the guy off was that it was missing a digit. and also numbers where slant.
    i have traced the motor with holden, and was confirmed early production V8, i had taken it from a SLE, along with everything else, besides shell.
  1. Engine Transplant 5L or Gen 3
    By sus_calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-09-2007, 10:49 PM
  2. Wtb: Vn For Engine Transplant
    By jamiekratin in forum Swap / Wanted to Buy / Trade
    Last Post: 12-06-2006, 04:49 PM
  3. Vk engine transplant
    By calais_freak in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 04:59 PM
  4. engine transplant
    By super_6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-05-2004, 11:02 AM
