Results 1 to 10 of 10
Thread: Electric aerial wont work...
    VN Executive Series 2
    Oct 2005
    Default Electric aerial wont work...
    Hi all,
    a mate installed a cd player and new speakers for me and when we tried to get the aerial to work, it wouldnt. it worked with the holden tape player in it.
    i talked to another guy and he reckons that when we pulled the wiring out to connect it to the cd player (we had like 3/4 of the dash out to do it) we may have pulled it out at the aerial itself...? but then i talked to my mate and he reckoned the wiring goes to somewhere just above the EST control unit?
    it was weird as my mate used a lamp to test the circuit but the aerial just wouldnt go up?
    Has anyone had any problems with their aerials?
    cheers
    Kurt
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Yep, it's up around there.Berlinas have the elecy arial aswell.Mine is the old steam powered(pull up yaself) type on the Berlina, my Calais arial works a treat & it's hooked up to come on wif the stereo.Got an original GMH spare one kicking around here sum place the Father in law payed $5 4 at a garage sale.Still in the box unopened.Wat a SCORE....!!!No BS.
    Tony 308vkcalais:
    Oct 2005
    sorry 308vk calais - up around where, the aerial itself or the EST control module?
    So yours stopped working entirely as well VK 308? I wonder why the hell this is so...?
    cheers
    Nov 2005
    EST Module in the Pass kick panel.You've most probly disconnected it at the stereo plug loom itself.Have another goose at your wiring.If the head set is a good 1 it should have an arial control wire on it to connect it to.I'll have a check of the Bible(The Gregory's) & see wat colour the arial control wire is.Pink comes to mind but i'll check...
    Tony 308vkcalais:
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Have a look on my site I have wiring diagrams for the stereo, you need to connect the remote (of on a decent stereo the electric aerial wire) up to the yellow wire going into the electric aerial relay box.
    cheers
    Scott
    Jul 2006
    I have a VC, does anybody know if they came out with elec ariels??? I havent seen one with it. "havent really been looking though" mine has one and it doesnt work either. I dont really listen to the radio anyway, but it would be allright if I could get it worken.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    yes the SL/Es had an electric aerial, same setup VB-VS that I know of prob even later than that as well. Basically its a semi-automatic aerial it goes up a little way then controlled by a switch.
    Jul 2006
    Quote Originally Posted by vkberlina View Post
    .......mine is a VC/L its got the up and down switch in the dash "looks like it was supposed to be there though, doesnt look out of place or anything" it just wont move at all.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    have you got the factory or after market stereo fitted??
    If you have an aftermarket headunit and the aerial is all factory connect your remote or power aerial wire from the head unit to the yellow wire on the cars stereo plug (Not the head units yellow wire)
    Otherwise at the antenna module it will be the brown wire.
    cheers
    Scott
  1. Electric Aerial
    By numchuker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2007, 08:36 PM
  2. Electric Aerial
    By porkkhunt in forum Car Audio
    Last Post: 28-11-2006, 07:15 PM
  3. Electric Aerial
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 04:52 PM
  4. electric aerial
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 07:33 PM
  5. electric aerial
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 10:42 PM
