Results 1 to 8 of 8
Thread: Buying a VK LSD
    VK 3.3L
    Dec 2006
    Default Buying a VK LSD
    Where do i look to buy an LSD for an 84 VK?
    VN/VT
    Sep 2005
    SA
    id try your local wreckers, commodore specialists etc, were abouts are you located
    VK Calais
    Feb 2006
    Try ebay, 4 pinion 28 spline LSD's go for around $800, usually no more. But you can get lucky, mine was $400.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    VK 3.3L
    Dec 2006
    I dont know much about commodores what kind will fit in it and im from bribie island qld
    DANNY8's Avatar
    Apr 2004
    Get under the back of the car and on the back of the dff it will either have a rubber bung or a metal bolt.....these are to check the oil level.
    If u see a rubber bung that means u have a borg warner, if u see a metal bolt it means u have a salisbury.
    VK 3.3L
    Dec 2006
    it has a metal bolt so what kind of lsd would you recommend for a cheap price
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    What your best to do is to buy a borgwarner diff from a VK or VL and do an LSD conversion on it, whilst your at it do a disc brake conversion as well.
    That will be your cheapest & best diff you could get, in the car it should cost you under $400 doing work yourself. Its pretty easy to do, you will need a torque wrench, some gear paste to check the mesh of the gears. To have new bearings pressed onto an LSD centre take it to a mechanices shop it should only take them 10min.
    Else if you have around $800 look at a 28 spline 4 pinion VL Turbo (3.45) or VL V8 (3.08) LSD.
    Now for a plug - I do have a 25 spline borgwarner LSD diff centre for sale, it was to go into my VK till I picked up a bargin on a VL Turbo diff. Diff build instructions to go with it.
    cheers
    Scott
  1. Buying a SV6
    By cladiges in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2007, 04:53 AM
  2. When buying a vz
    By knight97 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-01-2007, 05:13 PM
  3. What to look out for when buying a vr
    By VKStevo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 11:19 PM
  4. Buying a VT SS 5.7
    By patullose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 10:37 PM
  5. maybe buying a vs on gas - what to look for
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2005, 06:11 PM
