Results 1 to 4 of 4
Thread: Front Dash
    1980 VC
    Jun 2006
    Fertree Gully, Vic
    Default Front Dash
    Hi everyone,
    im pulling apart my front dash in my '80 VC and ive hit a little bit of a bother. in the middle where the switches are (eg. AC) and where the clock is. i think its called the bezel. the second switch from the right wont come out like the rest. if anyone has any advice it would b a big help.
    Spike79's Avatar
    Spike79 is offline Just Confused!
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    Bubble Shooter Champion! X-Pipes Champion! Alu`s Revenge Champion!
    Feb 2006
    Brisbane N/W Ferny Hills
    Is that the wiper dwell switch?
    It has a knob that you turn to change the wiper speed.
    If so, just pull the knob off the switch, there may be a little pin holding it in place from memory. I think you can then unscrew the round peice behind where the knob was. Then you should be able to pull the switch unit out from the back of the panel.
    Sorry, i'm a little sketchy on the details. Its been a while since i've worked on a VB/C.
    Mike's VP Berlina LX... Click Here
    Mike's VZ Adventra LX6... Click Here
    Mike's VP - Most Stock Award - March 07, October 07, April 08
    VH SL Wagon
    Oct 2006
    Mackay
    The knob should just pull off then use a flat screwdriver to unscrew the nut then i should just push out, or if you are taking the switches out all together just unplug the wires off the back
    1980 VC
    Jun 2006
    Fertree Gully, Vic
    yeah its the wiper speed knob. thanks guys ill go try it right now.
  1. Front Dash
    By Gavdog15 in forum Electrical Wiring / Questions
    Last Post: 15-01-2007, 10:15 AM
  2. Front dash fascia ??
    By andrewmac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2007, 08:06 AM
  3. WTB: URGENT: VL Front dash
    By SuperStar in forum Swap / Wanted to Buy / Trade
    Last Post: 15-04-2005, 09:22 AM
  4. WTB: Urgent: VL Front Dash
    By SuperStar in forum Parts And Other Items For Sale
    Last Post: 15-04-2005, 09:20 AM
