have worked franticly getting the panels on this straight...
Both front doors and 100% left rear is 100% right rear has a little high spot, right front guard is a brand new panel but i had the ariel hole welded up, right front guard is 100% straight, Right quarter is 90% roof is A+ boot lid is 100%...The left rear quarter panel has a small carpark dint...I have a brand new bonnet too....
ROLLING GEAR
Brand new reconditioned VL TURBO diff with 28 spline axles and 35's gears, new disc rotors with new reco calipers, new nolathane bush kit and nolathane panhard rod, new low king springs and new munroe low shocks, new lower control arms...
New one piece tailshaft with all new rubbers and braces...
Brand new reconditioned trimatic transmission with a stage 2 shift kit and a 2500 stally...
I have the paper work for all of these parts they were installed this year and have not been used since install...
Brand new front suspension strut inserts with new nolathane bush kit and nolathane top bearing assembly, new low king springs, new disc rotors and new reco calipers...
Recondition Stage 2 Gas Red 308
Trimatic Pattern
Motor was reconditioned this year on the 14/09 by Gown Hindhaugh Engines Pty.Ltd
Full Long Motor Recondition Assy 308/LPG
Eng #QT514118
030/.001/.001 Rope
Brand New Valve Springs, Full Bearings, Full Gasket, Welch plugs, Oil Gallery Plugs, Cam Plugs, New Harmonic Balancer, New Lifters, pushrods, Rollmaster Timing Set, Water Pump, Oil Pump
Brand New PLG Stage 2 Crow Camshaft
Heads and Manifolds Decked and machined
Brand New Purple Anodised Rocker Covers
Also Comes with Standard 4 barrel Carby, Electronic Igntion Dissy,
Does Not come with alternator, power steering, Thermostat,
Motor Is sitting in car but is still in original mechanics glad wrap...
Only Selling because i decided i want more power...
Beat the feul costs and have power plus economy with this motor
If you want a certain part contact me and I will consider selling seperate I will alos help to remove
NONE OF THESE PARTS HAVE BEEN USED SINCE BEEN ON THE CAR
if you want pics let me no as there are too many to post all
any chance of some pictures mate? i have a project Vk i sourcing good parts for, to do a rebuild in the future so you may have some parts of interested to me.
cheers, Pat
pics were sent to your hotmail...Regards
cheers mate!
