Results 1 to 15 of 15
Thread: xf carb
    vr 5 speed
    Oct 2003
    Default xf carb
    i think it was a xf or might have been xe, can't remember but where would u get the adaptor plate from the old carb on the vk's to the falcon carbs
    cheers
    scott
    p.s is it easy to do?
    I don't stay with my my wife for love, spite really, i won't leave her cause that'll make her happy!!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok I am about to do this conversion when I get some spare time.
    You can order an adapter plate through Autobarn or Supercheap put out by a company called redline.
    Also the original company I found that do them in lynx have a look at http://www.lynxcorp.com.au/shopping/...18&Value=29.15
    It looks pretty close to being on the money although I havent confirmed it yet.
    My next stage will be to head to auto barn or supacheap and get them to get a price for me. The Lynx one is around $30.
    Problem with the conversion.
    The Weber uses an electirc choke controled from your alternator, so if this isnt hooked up the car is going to be a bitch when its cold. To get around this I have been thinking of using the air bypass from an EFI VK its temporature controlled I should be able to get it to work, The main reason im thinking of using it is its sitting in a box left over from my VK as im installing aftermarket EFI.
    Other option is a switch on the dash with a variable resistor
    *mind you its only theory I havent tried any of this yet*
    Another option which has been used before is an adjustable voltage controller chip (Like a FET) and run 7v to the choke. Make sure you run it off your ignition.
    Other things you may have issues with are throttle linkages & vacume lines.
    I have a weber sitting at home in a drum os deisel waiting to be rebuild & bolt on. I have had an unexpected engine rebuild in my good car so its delayed this for about a month.
    Also have a read of some of the older threads on the forum the same question has been asked in the last month or so.
    cheers
    Scott
    vr 5 speed
    Oct 2003
    i know but no of them told me whee i can get the adaptor plate from.
    i don't know but this does not seem to be what you are talking about, it reads like this under the picture of the plate
    "Product Name: ADAPT KIT DCD 238 GM 4CYL
    Your Price: $29.15 "
    i am more concerned about the 4cyl part
    cheers buddy
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    If oyu contact your nearest auto barn or supercheap they _should_ be able to give you the exact part number. I wasnt going off description rather the picture going off what the carbies look like.
    the conversion is on my list of things to do but at the moment im rebuilding an engine for my good car, so playing with the runabout isnt happening
    cheers
    Scott
    vr 5 speed
    Oct 2003
    vr 5 speed
    Oct 2003
    ok bad news i rang up a carby place to see if i can get the adaptor plate and the guy i talked to said i would have to start re-drilling???
    so i figured it wasn't going to be as simple as i thought.
    cheers
    scott
    p.s but what is simple to do with cars
    mixin is offline Ol' fart, young heart!
    May 2004
    Country Vic
    Don't be worried with the 4cyl comment - camiras & VC/VH 4cyl ran the same basic varajet as the VK carb (just recalibrated).
    vr 5 speed
    Oct 2003
    i think i am going to scrap the idea but thanks anyway
    cheers
    scott
    snuff Guest
    Heres some info I found while searching for information on this conversion awhile ago. (BTW I have no idea who "John" is)
    >> If available a commercially available adapter plate, bolt on solution,
    >> anyone know who might sell one?
    > Redline do an adaptor plate, and all the linkages that you'd need to
    > set this up. You can order it through any Autobarn, and probably
    > Supercheap, for that matter. If the guy behind the counter doesn't
    > know, Redline products are distributed by ET Performance. But they
    > should have a Redline catalogue lying around somewhere. It's even got
    > a section where you can look at the car, and look up the carby, and
    > it'll list all the part numbers you need to set it up. The carby in
    > question is a 32/36 DGV, I believe. Should go well on your 202.
    > <snip>
    >> Next question, what differences would I be likely to see by using an
    >> adapter plate instead of making my own manifold?
    > I believe that if you made your own manifold, and set it up right, you
    > *could* get better throttle response or more power, depending on how
    > long you make the runners. John's probably the man to explain this
    > better. For this application, not worth the bother, imho.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Hi Guys,
    I looked into making my own manifold, actually modifying an EFI manifold but its too muchwork for me at the moment. KC also do an adapter plate, it looks like the way to go for a street car. Last price I got was around $35.
    Anyway I have come across a complete EFI setup for my daily driver so im not bothering with the XE-XF carb. Anyone want to buy a complete cheap carb? reasonable offers accepted.
    cheers
    Scott
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    vr 5 speed
    Oct 2003
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    NSW Central Coast. If you want I can post Pictures of the carb. Its currently soaking in a drum of deisel. Well its been there for the last 3 months Soaking it helps remove and soften carbon and other gunk. I would put a rebuild kit though it before I use it though as it was sitting on the shelf where I purchased it from for some time.
    If you want it posted I would need to dry it and blow it out before I could ship it anywhere. I actually have been doing a clean out of alot of 6cyl 202 bits making room for soon to be arriving EFI V8.
    I have a disassembled 202 race engine requiring rings bearings block & gaskets. I will be posting a parts list in a few days when I finalise pricing.
    cheers
    Scott
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Hrm, I'd be interested, esp. if you ran a rebuild kit through it
    You got any decent Holley 2bbl manifolds to suit the 12 port head? I figure I can run a Redline or Cain manifold for the Holleys and track down a Holley -> Weber adaptor plate - no doubt a ####load easier to find than a Weber -> Varishit
  15. #15
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    carb sold as is I dont have time to rebuild it. Im devoting my time to a V8 conversion on my good car.
    Carbs are easy enough to rebuild, last kit I bought for a varajet was $28, weber shouldnt be much different. The kit comes with instructions as long as you pull it appart and take note where everything goes its a piece of cake probably take a couple of hours if that, just dont skip things or try to cut corners esp take your time getting your float level right
    I tried a few different float positions on the varajet on the car im driving atm and found 7mm worked better than the recommended 8mm, unless the ruler was out
    I have heard the holley carbs dont go so well on the 202s could have just been the size or something they were using but, if your chasing power just go EFI dont waste time with a carb.
    If you want to put the weber on just buy a adapter plate wont cost much. I could see the whole job buying the carb, rebuild kit &adapter plat costing about $100-$120 all up
  1. Which Carb??
    By vb_commie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2007, 05:43 PM
  2. 202 carb
    By VH_Commodore_Wagon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2006, 07:20 PM
  3. Me and my Carb
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2006, 09:16 PM
  4. Varijet carb adaptor plate for XE carb
    By trophy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:53 PM
  5. Vk Carb
    By xstatic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2004, 05:06 PM
