Results 1 to 10 of 10
Thread: loss of power
    vh commodore/ VC commodore
    Nov 2005
    QLD
    Default loss of power
    i have a VC commodore 253 V8 and i am having a bit of trouble with the engine when i start it up it's idoling a bit rough and when i put it i gear and go to take off i loose power and have to put the clutch in to stop it from stalling.
    Any help would be great
    Thanks James
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    carby could need a slight adjustment, also is your choke working properly?
    We got rep back, yaaay!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it's only doing it cold it is probably a choke problem, if not then I'd say you have a vacuum leak. What carby you got?
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Do you have a Stromberg or Quadrajet? Sounds like the choke isn't working properly. Mine does the same thing and gets warmed up eventually.
    Nov 2005
    QLD
    i have a 4 barrel carby but not sure on brand i will have a closer look on monday because i wont be here over the weekend. yeah when i give it a little rev it sounds like it's sucking a whole lot of air like to much i think.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    I'd look your air cleaner seal if it has one, maybe other joints and seals around the area where the noise is coming from.
    Little leaks if fixed can solve major problems.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    it could also be your fuel pump, if it dies when you try and drive. thats what mine vk does when i have little fuel in the tank.
    Goon's Avatar
    Feb 2006
    GC. QLD
    She could either be having the problem also if..
    a # Shes running cold
    b# Idle on the carby is abit off.
    c # Choke.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Goon, A & B of your answers won't make the car run like his and mine. I would bet money it would be the choke because mine does the same thing. Thank goodness it's summer or I would be waiting forever until my motor warms up until I touch the throttle.
    If the idle was a bit off, it would let you drive it fine but would just run like a barge on standstill. If it's cold, same thing but the choke is there to comfort the cold.
    OP, what do ya reckon'?
    Nov 2005
    QLD
    my carby is a rochester quadrajet... still the same case?
  1. Loss of power...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 01:01 PM
  2. Loss of power
    By BLUE_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 11:23 PM
  3. what causes power loss
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 10:20 PM
  4. loss of power
    By rail in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 04:54 PM
  5. Power Loss
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2004, 09:11 PM
