Results 1 to 3 of 3
Thread: Antenna is down and wont come up on my VC
    Nov 2006
    Default Antenna is down and wont come up on my VC
    Antenna is down and wont come up on my VC i can push it and it feels springy but i cant get it up is there a way to do it?
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    they have a spring loaded lockdown on them, you will see a little horizontal slot on the front of the mounting nut and that is were you unlock it from
    VK/SL 3.3l AUTO SED.
    Dec 2006
    Eastern Burbs Melb.
    Default Locked aerial
    He's right, unless you have the one with the slot in the top of the aerial. That's still poke a screwdriver in and lever it clear of the mounting nut. Only other choice is take the mounting nut off and check out how it works from under the nut. Better yet replace it with a fully auto aerial. Goes up when you turn radio on down when off. If you bend or bust the mast you can still get replacement mast and rope from Repco and Autobarn etc., and they are easy to re-fit for the broken one. That's if you buy a decent brand "maybe like Aerpro". Ok.
    No it's not NOS it's LPG
    Good Rep points are always welcome
  1. Tv Antenna?????
    By Scott98 in forum Car Audio
    Last Post: 08-01-2008, 08:57 AM
  2. antenna
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 05:10 PM
  3. Vs antenna
    By VSAccCom in forum Electrical Wiring / Questions
    Last Post: 18-10-2005, 10:17 AM
  4. VS Antenna!!
    By danny6424 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 04:22 PM
  5. VL Antenna
    By Aussie_Watto in forum Car Audio
    Last Post: 05-07-2005, 05:39 AM
