hey i can get to the allen key bolts at the front of the seat but it wont slide far enough forward for me to access the back 2 bolts
am i doing something wrong
please help us out
must be jammed.. spray some rp7 or something on the rollers.
While you're at it, spray some on the underside of the car where the bolts are.. it will make it a lot easier to get the bolts out!
use a ratchet and drill bit. thats what i use.
cheers all good now...
just were jammed..
wd 40 is your friend
some seem to have 13mm bolts and some have allen key bolt thingys
used a shifter and breaker bar
spray cans ftw!
i used an allen key with a hollow metal bar for leverage... hasnt failed me yet!
