Results 1 to 2 of 2
Thread: polishing ports on 202 head, backyard job , Please help
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    Default polishing ports on 202 head, backyard job , Please help
    hey guys a guy at work told me that i can polish the ports on my head at home rekons it will take bout a day or so. has anyone done this or herd of this being done with success?
    any comments wold be much appreciated.
    cheers vks
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    You can do a bit of a port job on a head at home, some things you wont be able to do and you wont get it as good as a pro would, but you can get close.
    When you port a head 2 things are mainly considered volume and velocity. The head should really be matched to the cam shaft, both valve size, springs, & ports.
    The biggest problem is getting each intake port then each exhaust port the same sizes. This is what will take time, matching the ports to your headers & inlet manifold. This can be done using the gasket as a template. Just make sure you dont go too far, check your water jackets.
    You will need a Valve Spring compressor, Die grinder & Tungsten carbide bits
    variety of grades of sand paper depending how far you want to go. I use a finger belt sander instead of doing it by hand.
    You will need to completely disassemble the head and clean it, I would suggest using a spare head, just incase you stuff up.
    Clean up your ports to your desire, then take the head to a head shop/machine shop to have new valve guides fitted, machined for bigger valves if wanted.
    Buy yourself a VRS kit, it will give you all the gaskets you need including valve stem seals which you will need when you reassemble your head.
    cheers
    Scott
  1. question relating to ports.
    By garfa in forum Car Audio
    Last Post: 27-11-2007, 10:32 AM
  2. My Backyard! :o
    By benzor in forum The Pub
    Last Post: 13-03-2007, 02:50 PM
  3. Yay For Backyard Panel Beating
    By KingDiamond in forum General
    Last Post: 01-09-2006, 01:36 AM
