Results 1 to 13 of 13
Thread: VK speedo
    VK berlina sedan 202
    Jun 2006
    Default VK speedo
    Hi Guys,
    Iv'e just finished school and I have just started my real job this week.
    I have noticed while traveling the distance to work that I tend to get tailgated really bad and overtaken heaps. I suspect my speedo to be incorrect, does anyone know a way to find out how accurate my speedo is?
    Also, with varajet carbs, when the float level is at say 4mm (Don't ask) and the idle mixture screw has been tuned at this level, if the float level was decreased to 8mm will the mixture screw need to be adjusted?
    Thanks
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Hey mate don't worry bought the tailgaters.....i was told by a cop once that if u ever hit someone from behind it's automatically ur fault coz u should have been concerntrating on the road and wats in front of u......so just slam on the brakes and hope they have insurance haha. But personally I wouldn't slam on the brakes....if I ever get tail gated alot of the time I slow down slowly, and when they go to overtake I give it some stick and they still end up behind me. But if I'm travelling slow I'll let them passed, but if they're speeding I'll piss them off! Hehehe.
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    get your mum or dad to take out there car travel to 60k and you travel on the side and see what your seedo reads
    We got rep back, yaaay!
    VK-Berlina5.0's Avatar
    VK-Berlina5.0 is offline turbo setup would be good
    VK 308
    Aug 2006
    down south
    Well my speedo reads slower than its going, when doing 50kph im accellerating away from everybody.
    how do I fix that? do I have to replace some speedo gearing or something.
    is it in the side of the transmission? cause there is something there, but im not sure.
    can somebody please help.
    Cheers....
    Scott
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Suspect the driven gear on the end of the speedo cable which goes into your gearbox. They can slip! I fixed mine by jamming a toothpick in it! No bull!
    VL
    Jul 2005
    SA, Mount Gambier
    what wheels have you got mate? also yeh in 100% of rear end collisions it the car behinds fault, no if buts.
    and again on the wheels, if you have changed ur tire profile / diameter then you need o change the speedo driven gear or calibrate ur speedo.
    VK 308
    Aug 2006
    down south
    yeh I changed my wheels, I got 235/45R17 instead of the old orignial skinny 14's
    how do u calibrate your speedo?
    and how do I know what speedo driven gear I should have, how many teeth and what colour should it be? Ive seen all different coloured ones. I think the colours are for the different number of teeth or something.
    any information will be helpful thanks.
    Scott....
    VK/SL 3.3l AUTO SED.
    Dec 2006
    Eastern Burbs Melb.
    You are right the different colours relate to the Number of teeth or ratio of the gear and which diff. centre it goes with. If you have a "Measured" Kilometre near home & time how long it takes to travel at a steady speed, say 60Km\hr., should take 60 seconds. Otherwise call in at your nearest speedo repair shop, they can fix it in minutes usually. When it takes us ages to work out, let alone get it right. It's worth the money to know for sure it's right, and not be guessing.
    No it's not NOS it's LPG
    Good Rep points are always welcome
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by VK-Berlina5.0 View Post
    Scott....
    Drive along side with your mate at you doing 100Km/hr. Is it fine? Ok! If not? Post here again!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yes there is different speed drive gears and driven gears. Depends on the gear ratio of your transmission, diff and tyres used.
    VK 308
    Aug 2006
    down south
    Quote Originally Posted by robbo10 View Post
    yeh i think i should take it to a speedo repair shop, it will be a lot easier and then when its finished ill know it will work hehe.
    Scott...
    VK Belina 304
    May 2009
    Cool
    my bloody wagon reads 80 ks wen im only doing 10ks . any1 have any ideas?its freeking me out
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    To test your speedo use a GPS, make sure its on clear open road no trees, etc to block view to satellites the more you lock onto the more accurate the speed.
    The type of gear you need depends on the wheel, diff & gearbox combo you have i have charts on my site. I also have a full range of good condition gears for sale starting at 18tooth up to 24 tooth.
    20th (white) ones are still available new.
    cheers
    scott
  1. speedo
    By craigvl038 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-04-2007, 05:29 PM
  2. Speedo
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 11:06 AM
  3. speedo off??
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 04:51 PM
  4. speedo
    By gungazza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2005, 01:56 PM
  5. Speedo's
    By gsmrobinson in forum General
    Last Post: 17-11-2003, 06:13 PM
