Results 1 to 6 of 6
Thread: Thermo fan wiring parts.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Thermo fan wiring parts.
    Hey All
    If someone could tell me all the wiring bits and pieces i need to install a thermo fan to replace my mechanical fan, i just want to check i got everything
    I got it off ebay lastyear & i didnt get instructions, so i cant tell if i have every piece i need.
    Cheers to who can help me out
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Parts wise
    Sufficient Wire
    Terminals for the wire
    Relay
    Thermo switch that you insert into the radiator hose.
    Fan & mounting hardware
    When I had my fan on my VK I wired it up with a switch on the dash, on when the engine was hot (regardless if the ignition was on) & on only when the ignition was on.
    cheers
    Scott
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    When I eventually get mine, my smaller fan will be wired so it turns on with the air con and the larger fan will be switched by a electronic control module from Jaycar which the fan only switches when the temperature is at a certain level.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    You don't need much. Just two relays for twins, wiring, connectors and a thermo control module from Jaycar (as a electronic kit) or a temperature switch which switches at say 90 degrees or whatever.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Sufficient Wire
    Relay
    Cool this is all i need
    THanks for the info ill be doing the same.
    I'll post pictures when ive finshed the job
  1. thermo fan on a 5L
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2010, 11:25 PM
  2. Huge Sale Vn Calais - Vs Parts Stato Parts Etc Etc Heaps Of Stuff
    By petezor in forum Parts And Other Items For Sale
    Last Post: 02-03-2008, 04:48 PM
  3. Wiring up a switch to the thermo fan?
    By VNracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2008, 07:04 PM
  4. Wrecking VN - Selling all parts! Includes parts from later models others non-standard
    By DavidPartay in forum Parts And Other Items For Sale
    Last Post: 27-07-2006, 11:35 AM
  5. Stock VS with alarm parts, wiring ?
    By digisol in forum Electrical Wiring / Questions
    Last Post: 29-11-2005, 10:27 AM
