Best thing i have ever done brought a wreaked VN out of the trading post slight front and side damage $350 Took all the gear out the wiring i took out intacted made it easy to wire up![]()
Have owned my commodore 4 yrs now brought it for $700 is only an SL but have put a sony stereo, remote central locking, Berlina door skins and HEAPS! of other gear on it Now for the biggest madest change!
were getting so sick of my carb 202 s*** to start in mornings used far too much petrol for the power it put out the last straw was the tappets and starter motor started to go on me so in with the new 3.8 V6
was great taking the engine and all out resprayed my engine bay looks like a newy the v6 vn K-frame bolted straight in no worries, the 4 speed auto is awsome! gear shifter was easy moded i found the wiring pretty easy radiator and all fits good i done all the work myself costed next to nothing the brakes and all are a straight swap aswell pissed off my rusting old brake booster off the vn one is like new!
thats so clean nobody would know u had a v6 in it
We got rep back, yaaay!
Nice work mate! You should be proud of that. Hows it run?
Thats an awesome job mate! How long did it take you to swap from 202 to v6? I'm thinking about doing it within the next few months but I don't think I can afford to live without a carAlso did you get a engineers certificate? How much was it? Sorry for all the questions
Thanks everyoneit took about a month on and off. yeah thats the prob having no car! i have another VK and a Hilux that i could drive haha the other VK was dumped here by my brother he brought an AU! YUK! na no engineers certificate yet i dunno if i could aford it, if i get pulled over im gonna be worried! but other than that it runs awsome! haha it spins the wheels so easy! as its lighter than a VN but i dont thrash my car, done the conversion for economy but its a good allrounder engine has loads more power than the 202 did. no worries bout the Questions
Im thinkin about doin the same to my vh...a few questions
rear crossmember? exhaust ? speedo drive? and tail shaft .....how did you get around these things?
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
http://www.v6conversions.com.au/ has all the parts in a kit, but you do need to source the engine and looms etc. Can't wait to see a V6 in a Gemini, that'll fly
1234567890
The auto gear box is a straight swap u just need to mod the VN shift rod to fit the vk's gear shift and as for the plastic VN selector i cut it on a band saw to fit the VK console the Exhaust is mainly the VK one that was on it as i just brought it a year ago cutted and welded the flange after the cat to the vk Exhaust but im sure an Exhaust joint could make one up but i try to keep the cost down on things!the speedo drive should work if u have a calais digital dash as the vn auto has a electric sender but you can get a cable made up to fit im useing the standard VK tailshaft and diff at the moment but latter on i shall change it
yeah has so much more power! over took bloody 4 cars up a HILL! and is great on ECONOMY na no kit required for a conversion to a VB/VL the VN K-frame bolts straight in yeah my black 202 had done 300,000 + on it when i got it 4 yrs ago even then it wasnt tickin the K's over on the dash so could of done alot more! only got the car coz i love the VK and because it was in excellent condition.
1234567890
Wow - looking at and reading about your conversion has convinced my that the V6 is the way to go, and I will be quite glad to asshole my injected 202!!
Yeah man nice work hey, i cant wait to c wot my VB will go like when i finish the conversion just a radiator needed cant afford one atm tho![]()
WIll need to change you sig now that its a 3.8 and not a 202 hahaha
.:Blown VT V6, DAJ37:.
How much did the conversion cost all up?
i reckon about 500 ish for the conversion the wreak car i got was a vn wagon was only $350 the engine is tight as! the only thing was, as it was a wagon the tank was wrongso i had to look around abit couldnt get any at nick a bit haha as they put holes in em to cover there selfs if a fool blows em selfs up, easiest way to drain em i guess, and i had to get a radiator as it was mashed, got it at pick a part hasnt leaked yet
! ill get some more pics up of the auto shifter etc i reckon i went ok haha just turned 19 ive started an apprentice at Toyota, is so borring only services mainly haha yeah piss off the 202 sig! were gonna throw the 3.8 badge off the vn on the back of my car but thought nope will only make the cops wanna have a look! id s*** me self will get it engineered 1 day.... Injected 202's are alright but they can either be really good or plain crap can be touchy, the black 202 carbs dont bother! a VB commodore would be awsome! i dont see many VB to VK's much anymore
i think its the ageing engines that turn people away these days people seem to just run their cars into the ground n get a newy. personally anything newer than a VK i dont really like.
Cos the my VK has fuel injection, I shouldnt need the tank from donor car eh? Just use the existing fuel lines?
KiwiKommy
if the vk has efi you dont need to change tank i heard.. and it only cost you $500? thats alright..
DaZ
Project: Shifty1 commences Feb 2007
The_Monk says:
im a leech
yeah if your VK is EFI use the tank pump and lines in it but yeah there is an issue with the filler but if worse comes to worse get a vn filler and just change it!or if u havent got an engine yet buy a whole wreaked car cheap as chips! and u will have everything u need the tanks are interchangeable but its gotta be sedan to sedan & wagon to wagon
so the engine transfer with trans only cost $500 because you did it all yaself?
DaZ
The_Monk says:
im a leech
yeah borrowed all the lifting gear and that off people i know (my uncle!) to remove and fit engines i think any1 is mad taking their car anywhere to be worked on, buy a shop manual and do it yaself!
