hey guys, i'm new to the Vb-Vk thread
I normally drive a VR but as it is broken i'm driving my parents 1981 VC 3.3L when turning the car on *when it finially turns over* the economy reading only sits at about 50 with a rough idal *is this normal* also when it starts to warm up and i stop at traffic lights it sounds like its almost about to stall and then the economy reading sits at about 25...I've changed to spark plugs and leads and this has not helped. also what fuel usage do people normally get out of a tank we are lucky if we can get 250km's
also how important is using the lead replacment as my parents never use it and it only gets used when i fill it up
any info on what could be wrong with the car would be much helpful
thanks guys
Drifting in a front wheel drive, is like going to maccas for an apple, Possible but pointless
Maybe do the timing, and possibly get the carby rebuilt.
My 173 always use to idle heaps rough, got it tuned, did the timing, no one knew why it was idling so rough....turns out it was a dodgy lifter haha
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
1234567890
It's pretty important to run the fuel additive through the leaded engines. The lead in the old leaded petrol provided protection for you valve seats, which unleaded doesn't provide. But, cars built for unleaded are already protected from this. Without you can burn out the valve seats and stuff your motor.
The closest you'll get to the old unleaded is to run premium unleaded with the flash lube etc. fuel additive.
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
Sounds like she needs a tune bro, check the timing also. take a look at the spark plugs if u can..
If your traveling on a highway u should be getting more then 250, if not switch to extractors and rebuild the carby.
A tune up i would do is timing and carby at the sametime. - I'll send u a pm
yeah or if its like my vh was it could be the auto choke not working mine was a pain in the backside to start on cold mornings and when it did start it ran like a dog til it warmed up enough and yeah check timing and just give it a good service new oil and filters and all the rest
