Results 1 to 12 of 12
Thread: VH Commodore
    Dec 2005
    Default VH Commodore
    Gday all, I want to pull out the tired 6 in my vh and drop in a 308, is the K frame thats present in the car would the 308 fit it.
    cheers
    John
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Yes. But do you really want to do it? You would also need to change the gearbox, tail shaft, brakes and diff.
    The reason I ask about you doing it, is because I know from experience what sort of work is involved. You would be a lot better off buying a 308 VK or VB or even a 253 VH and transferring any bits over to the new shell. There is a lot of options. Let me know what your plans are and I and others will give advise.
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    im thinkin about doing this in a few months so i'll let you know how i go although im lookin at getting a donor car
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    lisavw28 is offline lisavw28
    VH SLX 4.2L v8 wagon
    Feb 2007
    I may have some parts that are of interest to anyone here. VH SLX 4.2L v8 LPG automatic transmission, Last 2 yrs New Pwer steering rack, New Water Pump, New Alternator, New Brakes (all 4 wheel disc), and suspension.
    (Brand New Tyres). 1 yr ago New Inlet Manifold.
    EF Almost Turbo
    Jun 2005
    I thought you needed to change the k-frame..
    Ive learned something.. let me know how it goes.. wouldnt mind doing something similar in the future..
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    VK 5litre, GSXR600
    Jan 2007
    gladstone qld
    (i have done it before) it's not that hard to do especially if you already have motor and box. Motor and gear box straight fit, just gotta get tail shaft modded, V8 radiator, brake booster, exhaust obviously. from memory cost me less than $1000 buying every thing new, but doing all the work myself. oh and i run the 6 cylinder diff for ages before it gave up on me
    pnishu's Avatar
    pnishu is offline satan left i took over
    1982 sl vh commodore X2 1 has a 253
    Apr 2009
    cranbourne
    has anybody put a stroked 350 chev (383) in a vh im lookin to do this but im not sure wat i have to do for it to work thanks
    Fusion's Avatar
    Fusion is offline Awww I bent my wookie !
    1982 VH SL/X, 1997 SII Calais .
    Sep 2008
    Colac Vic.
    changing from a 6 to an 8 is pretty easy this is the second one i am doing . No need to get the tail shaft modded . Will be cheaper and easier to get one from a wrecker . Change to the bigger brake booster . 4 wheel disc brakes , radiator exhaust and some pills to relax the big smile you'll have once it's going
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Putting a chev into a early girl commodore is not cheap, not easy and may not pass engineering/rego
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    ? front struts are different 6 to 8 right? and the K frame has the engine mounts welded on it. i assumed they were different. so the 202 uses a 90 degree mount?!?!
    VH SS
    May 2009
    Toowoomba, Qld
    exactly the same k-frame between 6cyl & 8. No need to change it. I did the swap on my last VH. Engine dropped straigh in.
    Only difference in the mounting is the rubber engine mounts themselves. Just buy a pair of V8 mounts, bolt them on and you're done.
    Struts are the same, just the springs are different if they are standard 6 cyl springs. Otherwise if aftermarket springs are fitted, they are usually the same.
    It's a really easy conversion. The V8 engine harness just plugs straight in where your 6 cylinder harness was. If you keep the smaller 6cyl diff, there is no need to change the tailshaft
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  3. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
