Just a qwik one....just bought some new tie rod ends, and the new ones don't have a hole in the thread to put a split pin, y is that? It has one of those nuts which have the 'plastic' sort of crap in the end so it stays tight, but I thought a split pin would still have to be used to ensure it WON'T come off.
Should I drill a hole in the thread for a split pin, or just not worry bout it?
Cheers,
Danny.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
nylock nuts wont come undone dude.....if your still not convinced then use a bit of medium strength threadlocker
Cheers mate, just thought it was a bit odd. But I'm sure if they are using them they would have to be safe enough.
Thx heaps.
