Hey there... Ok .. Ive fitted the SLE dash into my VH and connected up the trip computer, all I need to finish that is fit the fuel flow meter.... now Im after any information that can help with teh latest problem, how do i get the low fuel light to work, I see there is a seperate plug on te back of the cluster.... would appriciate any help here.
Did you check to see if the vehicle you robbed the dash from had a different fuel level sender in the tank from standard, maybe with an extra wire to it that's not in yours. You might need that same type fuel tank sender unit to get the dash to work. Check the wiring diagram back from the light on the dash to see where it hooks in. Whether it connects to the flow meter, or the tank sender unit. You may not have all the wiring bits you need. I hope you remember where you left the wreck.
No it's not NOS it's LPG
Good Rep points are always welcome
