Does anyone know if you can fit VL Calais side mirrors to a VK Calais? I know they should bolt in with no dramas but mainly concerned with the wiring, is it the same?
Cheers!
I'm pretty sure if they have the same switch itll be fine
I can confirm VK calais & VL Calais mirrors are the same.
cheers
Scott
Thanks People!
If anyone has a passenger side one they dont need (preferlably in melb) let me know
Everything bolted in fine. The only problem is that they are a little noisey. Do you think that it would be ok to just spray the inside with some wd40?
would the power mirrors fit on a vh sle?
yes .
are they hard to wire up?
No not really 2 relays, mirror switch, connectors thats about it. I have a wiring diagram on my site
cheers
Scott
and suprising enough they fit on vb's
