hey i need 2 relpace the starter motor on my carby black 202 an was just wondering if its ok to replace with one from a wreckers or best 2 buy brand new?
that and also for the sa guys, were abouts would be the best place 2 go 2 get 1?
cheers, nick
Yeah a second hand one would be fine as long as it works ok. Try U-PULL-IT.
To change them over tho u gotta remove the exhaust manifold, so the intake and carby will have to be removed as well.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
good secondhand or new which ever you can afford it wont really matter. Try to buy a small bodied one as it will be easier to fit & remove later on. The small bodied ones are actually higher powered than the original larger bodied types.
cheers
Scott
