Results 1 to 6 of 6
Thread: Turbo 350 Needed Urgent
    VE SSV
    Feb 2007
    gosford
    Exclamation Turbo 350 Needed Urgent
    i just bought a turbo 350 off sum bloke was told it was good got it home put it in the car. turns out it basically cracked in half so i need a turbo 350 urgent dont wanna have to put the old ****-o-matic (trimatic) back in.
    or if anyone wants to buy a VB SL/E minus gearbox contact me. it has 10 bolt diff, 5lt with L34 heads, edelbrock manifold, holley 650, mild cam, 50-125HP shot of nitrous oxide , 18 inch VY SS rims, VY front brakes (300mm slotted rotors with twin piston calipers), B&M mega shifter and a wood grain steering wheel. on the nos i expect high 12s down the quarter mile and high 13s N/A.
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    try wreckers, does it need to be worked or will a stock one do fine?
    We got rep back, yaaay!
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I didn't know you could bolt a turbo 350 up to a block that had a traumatic. They are a different bolt pattern
    VE SSV
    Feb 2007
    gosford
    yeah it is differnt. ive got a 253 and a trimatic in it and swapped over to a 308 with turbo 350 but now im ganna have to put the 253 and the trimatic back in.
    VP Executive R-spec
    Jan 2005
    I've got a stock T350 buuuut I'm half a big country away and I might want to keep it??
    VH SL/E 1982 commodore/WB ute x2 VP commodore
    Nov 2005
    Cairns Far Nth Qld
    i have one here if still needed it had a little work done to it call me and we can talk but leave it till Monday pls
    Shawn Johnston
    Cairns Far Nth Qld
    Mobile:0488 530 009
    MSN: sbj_security@hotmail.com
  1. Urgent help needed
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2007, 08:20 PM
  2. Urgent Help Needed
    By Keeper85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2007, 08:32 AM
  3. urgent help needed
    By tomwallace in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2006, 01:12 PM
  4. Urgent Help Needed Now!!!!
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 08:49 PM
  5. URGENT help needed please!
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 02:31 PM
