Just wondering if VK sedan rear bumpers will fit a wagon?
Cheers,
Danny![]()
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
i thought the sedan rear bars were taller if you know what i mean, if you measured from bottom to top of a sedan bar and a wagon bar the VK's would be longer..no idea if that would effect how it fir or not though. i have seen sedan bars put onto wagons before but i have no idea whether the mounting points are the same or not.. sorry
I doubt it, but its worth a try anyway.
The wagon bar is a different shape to allow the tailgate to open. The chrome strip along the top of the bar on the sedan goes all the way around, which will probably stop you from opening the tailgate .
Mike's VP Berlina LX... Click Here
Mike's VZ Adventra LX6... Click Here
Mike's VP - Most Stock Award - March 07, October 07, April 08
unless you mount it a cm or 2 lower then it would be fine?
heres a pic of a sedan bar on a wagon..
a very modified wagon![]()
edit: if the rear bars are the same size maybe just the middle section of a sedan one would fit to the sides of a wagon bar?
just a thought...
the sedan bar houses the number plate where as the wagons doesnt its on the tail gate
