Results 1 to 3 of 3
Thread: VH Commodore Disc rear end
    Dec 2005
    Smile VH Commodore Disc rear end
    Gday there ..... Ive got a vh comodore with a drum rear end and about to fit another diff but a didc brake rear end....is there any changes to the brake master cylinder or will the disc rear end work fine as is.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    The drum brake rear master cylinder is a single diaphragm, doesn't have much pressure. With a disc rear master cylinder it has 2 diaphragms and much better pressure.
    In other words, better get the correct disc brake rear master cylinder, they are a lot bigger in size than the drum brake version
    VK SL EFI/ Monaro CV8
    Sep 2005
    I have done this job on my Vk. (rear drum to disc) It would be a good idea to change the diaphram brake booster to the twin diaphram booster and if possible fit a 1 inch master cylinder. With these specs, you would match police/Brock set up.
  1. Fs: [vic] Vk Disc To Disc 3.23 Rear
    By synoptica in forum Parts And Other Items For Sale
    Last Post: 11-12-2007, 11:52 PM
  2. disc rear end
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2007, 10:04 PM
  3. will vp rear disc fit vl rear drum
    By kowan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-01-2006, 08:16 PM
