Results 1 to 4 of 4
Thread: door trims
    VH SL/X
    Apr 2006
    Brisbane, Queensland
    Default door trims
    Hi,
    Just wondering if VL door trims would fit on a VH. And if so, can the locking mechanism be modified to use the VL horizonal-style latch?
    Thanks,
    Matt
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    I don't think you cqan change the lock. You may need to pull the hole locking setup off the vh and vl and swap i not sure? BUT if you can find a one, Some Vks have the pin lock like Vh's. I have only seen one and it was an 84 berlina and i was told it was because it had central locking? If not find some vk/vl doors the same colour as you vh and put them on! i know the front doors fit but you may run into some problems with the rear doors because vk and vl's don't have the vent, they have a window.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Yes the VL door trims will fit your VH. You can use the VL style clock mechanism, the rear doors are easy to do, the fronts i don't really know what goes with them. But you can use them easy.
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    i have to do the same thing to my vh i just got vh sl/e door trims that have the slide locks i have the pop up ones let me know how you go or if i finish first i'll let you know
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
  1. VR/S door speaker pods in vn ss door trims?
    By dawg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2007, 09:42 PM
  2. VR Door Trims?
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2006, 09:01 PM
  3. Replies: 2
    Last Post: 29-08-2005, 08:01 PM
  4. VY Door Trims Into VX
    By Knux in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2005, 08:10 AM
  5. How to get off door trims?
    By mazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 02:22 AM
