i wont be the first to say the holden 202, compared to todays standards is most definately lacking power ... i am not as of yet lookin at replacing the engine in my holden vc so. to you mechanics, what are some cheap ways to gain a few extra kw.. & whats the more expensive ways? note i already installed a custom 2.5"exhaust system ....
Extractors, cam, removal of standard fan and standard air box are good starters. Depending on how far you want to go, you could look at having some head work done etc.
Take the 2 1/2" off and go 2 1/4". As frenchyvh said, extractors, cam, port and polish head, bigger valves, roller rockers, solid lifters, flat top pistons, chrome molly push rods. The list goes on. For the 5g it will cost to make a bullet proof straight 6, spend it on a VP. Bugger all to spend, mods are easy and it will go harder than everything up to the VZ.
But cheap and easy, just go extractors and a webber carby from an XE or XF.
Get Extractors and EFI screw the ford crap off, get a good aftermarket computer and you'll do fine !
5 Speed, maybe a better driveline, lsd diff so u can boot her! See what u can do wit h the crank.. see if u can get any shaved off.. maybe improve in high or low end torque. Get twin VT"s if u can for thermos. Make sur ur engine internals are balanced, eg. dont have good pistons with shiat rods or lifters.
That's all ill say![]()
^ the carb is completely different isnt it? & why swap a 2 1/2"with a 2 1/4?webber carby from an XE or XF.
wht do you mean here?Get twin VT"s if u can for thermos
also , as far as extractors .. im willing to pay the money for pacemakers or genie etc .... but if i was to put vk extractors on (which im thinkin about), how much extra kw are we talking about? thanks for the help brothers.
The VT twins are two radiator fans... I think they are electronically driven and don't use belts?
VC Sleeper - It will improve torque = quicker rpm! better fuel eco, runs cooler then a standard exhaust. I installed VK's on mine myself, keep the other half the 2.5 exhuast, i would of chossen a 2.25 myselfseeing a 2 sucks and " 2.5 might be to big for a 202...everyone has there own opinion on this" but 2.25 in the middle!
The electric thermo will replace ur mehchanical fan, takes allot of pressure of your motor in its turns.
Hey i have a vk 202 n i was talking to my mate he says that ppl undersetimate the potential of 202s and taht u can turn them into 12second cars if this is true how?
(ps. im not tryin to steal ya thread mate)
Thanx
for the money you'd spend pulling the motor down to hot up you could buy a 308 out of the trading post, even a stock one would **** on a blue 202
thanks heaps goon very handy info. with the vk extractors... say if i dont have efi, do i have to buy the extractors from a vk with carb intake? or do both vk efi & carb extractors fit the same on any 202? also ,when converting to efi (highly interested) .... how much money am i looking at & whats the process? if you dont mind me asking..
converting to efi shouldnt cost you more then 400 bucks
Buy the latest Street Machine mag, it's got a large article on how to do up 202's.
i know its a dum ass question, but with the weber carby ... do i need a weber spacer?
Yeah you'd need the webber adapter plate if ur chucking it on a standard intake. Also the EFI extractors won't fit on a carby motor. They bolt up fine, it's just the intake manifold doesn't fit on with the extractors.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
my VH has a blue 202, through a 5 speed and it has headers and a 2 inch lukey almost staight through system, twin carbie, if the fanbelt stop slipping it'd be great, its a new fan belt too and done up right. starts slipping @ 3000 RPM
F.O.R.D
Forget Out Running Datsuns
