Results 1 to 13 of 13
Thread: vk v8 starter motor change
    Vk Berlina 308
    Jul 2006
    Default vk v8 starter motor change
    can anyone tell me how to change the starter motor in the vk..
    it is a 308 with stock exhaust manifolds... the manual says to undo the flange at between the exhaust pipe and the exhaust manifold, then to raise the engine 50 mm??? will this do it???? also does anybody know if a later model gear reduction starter will fit with stock manifolds??
    cheers
    Vk Berlina 308
    Jul 2006
    Vk Berlina 308
    Jul 2006
    Vk Berlina 308
    Jul 2006
    can anyone confirm
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Vk-5ltr Berlina View Post
    thjanks for nothing wanks
    People have lives. No need for that sort of crap.
    If you have standard manifolds then it's possible you need to remove the left hand side one to get the starter motor out. With my car having headers, I am able to fiddle and remove the starter without taking the header off.
    Disconnect the positive terminal on the battery. Remove the manifold to pipe bolts that hold the flange on the left hand side of the motor. Take the large battery cable off the starter motor using a suitable spanner. Pull the starter motor solenoid wire off the starter motor solenoid cap.
    Undo the two bolts that hold the starter motor on the block. Withdraw.
    Installation is reverse except note:
    The condition of the gasket may be perished. It's possible the flange may not have a gasket but a metal ring on the flange. Discard and replace with a new gasket if nessesary. Clean the flange gasket surface to remove any gunk before replacing the gasket.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    cheers
    Yes it definately should being more compact but there will be no benefit for that type of starter motor unless the motor is a high compresson type. I don't have one in my car because my compresson ratio isn't high and I would waste an extra $60-$70 for nothing.
    Vk Berlina 308
    Jul 2006
    cause i want a starter thats new and more powerful..
    i have also heard that the solenoid doesnt clear...
    basically everyone says anything will fit a vk 308 but so far only the stock items fit and i cant find one in good condition
    Vk Berlina 308
    Jul 2006
    Quote Originally Posted by craigvk View Post
    sorry slim thats trew... i just get so frustrated at not being able to fix **** sometime...i have pulled starters in and out all week with them either not fitting or not even working.. how much for an auto leccy to rebuild the standard one
    the lightning
    Jun 2005
    under the Southern Cross
    Craig, you're a bit more diplomatic than I would have been...
    anyway, if you wanna get your current starter rebuilt and are in melbourne's east, then PACE Auto Electrics in Blackburn South have always been good to me with work they've doen for me and advice when I choose to do my own Auto Elec work... good luck.
    ps I dont envy you changing a starter, I have big competition extractors in my VK and everything is very tight, I'd have to drop the extractors before I could even look at the starter...
    Vk Berlina 308
    Jul 2006
    lol yer its pretty tight but i just lifted one side of the motor and hey presto she came right out....
    its no fun when you have you pull them in and out either...
    im soo agitated i could buy a ford laser tommorow and be happy that it runs well
    the lightning
    Jun 2005
    I hear ya, just take a step back from it and cool down when you get like that, i find that I always fix one thing and **** something else up in the process if i press on workin on cars when im pissed off. doing that works for me 95% of the time.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Recon starters or change overs vary in price at auto elecs. They can be somewhere between $120-$170 as I have seen in the past. I was even quoted a new one at Repco for $160 but it maybe wasn't a genuine Bosch one. On the other hand, my brother had his starter motor replaced with a new one as the old one was so tragically cactus inside! Ebay sometimes have new starters and gear reduction starters. Worth a look for stuff like that in the future.
    Also I remember an auto elec telling me once that the red motor starters are different to the blue and black 308 starters. I am not sure if this is true or not, I'd like to know.
    Vk Berlina 308
    Jul 2006
    well im not sure but i have found out that hq-wb v8 starters wont fit a commo but commo starters will fit hq-wb.. i have since discovered all v8 starters vb-vr are the same...then the vs bosch ones which will only fit a vk with certain brands of extrctors... pacemaker are one that i know of
  1. How to Change a Starter Motor
    By PaRaDoX in forum Holden Commodore How-To's
    Last Post: 07-03-2011, 03:23 PM
  2. starter motor vn v8 - vn v6
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2008, 12:58 PM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. VG ute starter motor
    By oldsurfiepete1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 12:58 PM
  5. vc starter motor
    By marky mark in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-11-2004, 10:17 PM
