Results 1 to 14 of 14
Thread: Exhaust Problem.
    SoulGrind's Avatar
    SoulGrind is offline §ôµÏG®ïñD
    VH SLX - VX SII Calais
    Aug 2004
    Unhappy Exhaust Problem.
    Hello all, Well i have a bit of exhaust problem. You see i've changed my 202 motor exhaust manifold to extractors (wildcats) and had a new exhaust system put in the car. I've got a 2 1/4 inch pipe straight to hotdog to straight through resonator to 2 1/2 inch dumpy.
    The problem is, When i'm driving at around 60kpmh or basically any speed i keep the car constant at, the car has a massive amount of bass noise getting into the car. Now i'm guessing it maybe the dumpy. I'm thinking this because its sitting under the car rather then dumping further out from the car.
    I want to keep the lumpy note but get rid of the massive amount of bass getting into the car.
    So any suggestions on what it could be? Straight through resonator or dumpy?
    How could i fix this problem?
    cheers.
    "Zooooom"
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    do u mean drone? thats what u have to put up with when u dont have resonators ...
    Going where no late model stato/caprice has gone before.... GAME ON!!
    SoulGrind's Avatar
    Aug 2004
    It's more then just drone.. It's bass drone. It travels right through the car. It still does have a somewhat lumpy note and sounds great at low rpms / idle etc. But once i start to put my foot down it just sounds horrid at i'm guessing around 3000rpm.
    Whats even more annoying is that most of the bass noise is on the drivers front side of the car. Everywhere else it isn't so bad.
    "Zooooom"
    VN/VT
    Sep 2005
    SA
    yeah i get a really bad drone 2, i think its just the perks of havin a 202
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I use to have extractors straight back to a cannon on the back and that sounded pretty nice. The dump pipe I doubt would do anything to the sound.
    SoulGrind's Avatar
    Aug 2004
    well i spoke to the exhaust specialist that did the car (Richard at Rowville Exhausts) he basically said the problem would be the hotdog. So i'll probably get him to change it to something that will remove the bass drone at the higher revs.
    "Zooooom"
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Use a 8x4 straight through offset/centre glass packed muffler on it. Teamed up with the resonator on the rear it should give you a decent note without the drone.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Definitely go the glass pack muffler with a hotdog on the back, I would also run the exhaust out the back of the caras you might get some sorts of echo off the road causing some sort of drone noise as well.
    cheers
    Scott
    SoulGrind's Avatar
    Aug 2004
    well the exhaust thats on it is the one i just payed for. So i don't wanna be changing out the entire exhaust.
    If the hotdog is whats making it have to much bass, then thats the only part i'll be changing.
    "Zooooom"
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    something else I saw recently by someone else who had a new exhaust on their 202 was they had the hotdog first and the muffler last, It should be the other way around muffler first and hotdog last. The idea of the hotdog is to remove the crackles pops and subdue the drone.
    Also make sure they put the hot dog on facing the right direction else it wont do anything.
    cheers
    Scott
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it is a spiral louvre design hotdog the openings need to face the rear or it will create too much back pressure, trap moisture and last about 6 months. The perf tube designs can go either way.
    You don't need to change the whole system, just put a muffler on the front.
    SoulGrind's Avatar
    Aug 2004
    I just had the hotdog changed to a small muffler. Sounds way better, still has a nice note without all the bass traveling through everything. I'm sure richard knows how to put on a hotdog. He's featured in hotrod mags a fair amount for his exhaust work.
    example of his work
    http://www.airide.com.au/product_inf...roducts_id/334
    Just put in Richard Rowville Exhausts in google and you get countless websites / forums talking about his work. Great bloke too.
    "Zooooom"
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I was clarifying the comment by vkberlina, and you would be surprised at how many 'specialists' don't know the correct way to fit a hotdog. Not in any way knocking Richard.
    SoulGrind's Avatar
    Aug 2004
    well, this 'specialist' solved my problem.
    I did it the wrong way, i asked him to put on what i got, rather then asking him what i should have put on. Live and learn..
    "Zooooom"
  1. exhaust problem?
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-03-2007, 07:11 PM
  2. weird exhaust problem maybe???
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 10:59 PM
  3. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  4. Exhaust Problem
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 06:34 PM
  5. Fuel / Exhaust Problem
    By ricardo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-03-2004, 02:54 PM
