Results 1 to 6 of 6
Thread: 5spd - 4spd borgy box's - Just a qwik one :)
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default 5spd - 4spd borgy box's - Just a qwik one :)
    Well currently I have a Borg Warner M76, which is goin into my VK wags when I get it this week, well I get the VK this week, but the trans is goin in when I pull the motor out to get a complete respray, which is once it runs out of rego.
    I know the M76's are weak as piss, and as I have a mild 173 gettin bolted up to it I'm guessin it won't last once I start doin a few skids. So I'm wondering if a 4spd will bolt up using the same crossmember, clutch cable, bell housing, tailshaft and clutch...or will I need to get new bits?
    When our next skid comp comes up I wanna swap diffs over with our SKiDWAGON, which has an everyday Salisbury 8 bolt, but she's now welded up. So then I can take my VK wagz out onto the pad and let loose. Instead of revving it up and dumping the clutch on the spot I'll take off then full lock and hopefully she'll start building up revs on the spot....I'm hoping she'll sit in 2nd goin nicely.....but yeah I don't wanna kill it, coz we just about killed the 202 in the SKiDWAGON from sittin on 5k rpm for to long haha.
    But yeah, will the 4spd just change over no worries? Not sure if it's an M20 or M21, but it has a holden 6 bellhousing bolted up, so whichever one came out with the 6's I'm guessing it is.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Holden 6 will bolt up just fine using your existing clutch, pressure plate etc, even the speedo cable is the same.
    I dont know if you would be able to do this in a burnout comp etc but if you attach 2 water squirters inside the wheel arches etc run off the rear washer bottle onto the tires it should help you spin them up easily without dumping the clutch. Once spinning they should keep spinning.
    cheers
    Scott
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    DANNY8's Avatar
    Apr 2004
    coz thats $300 and the one I'm looking at I'm hoping to get for under $100 Would ya swap sumfin for it?? I got a spare VL diff sittin under the VH, won't go under the wagon without to much stuffng around so I may as well just buy a VL wags diff. Wat about $100 and the diff? lol
    Cheers for the idea Scotty, might look into that. Could have a tank in the spare tyre well and have a hose exiting from the drainage hole to go to each wheel
    Sep 2005
    is that 100 dollor one rebuild with brand new clutch and come with flywheel and shifter and all the other crap
    DANNY8's Avatar
    Apr 2004
    Nah not rebuilt, comes complete with shifter and bellhousing. I got a new clutch anyways, retailed for bout $330....got it for $150 tho coz we put it under Brad's name :P
  1. EFI 202 Computers..qwik Q's
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2007, 10:33 PM
  2. Qwik strut mount question.
    Last Post: 08-05-2007, 12:05 AM
  3. f;s vt exec commodore qwik sale
    By sam611970 in forum Parts And Other Items For Sale
    Last Post: 24-05-2006, 08:40 PM
  4. Power steering Box's VZ to VP
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2005, 04:05 PM
