Results 1 to 6 of 6
Thread: Replacing rear quarter panels
    matty88's Avatar
    matty88 is offline LPG Installer :p
    TEXXXY: Resprayed TX3 Non Turbo
    Aug 2005
    Doveton
    Default Replacing rear quarter panels
    How easy is it to take out the RHS rear quarter panel, get it painted up and replace it? It's for a VK Calais.
    wagon
    Nov 2006
    South East Vic
    Too hard to be painting it off the car...they need to be fitted welded, bogged, primed, sealed, the painted....not easy unless you plan to ur sticky tape or super glue...same with ay rear quarter plannel, assuming you mean rear, some people call the front guards quarter panels...
    matty88's Avatar
    Aug 2005
    Doveton
    Well it's got a few rust holes/spots in the panel, and I don't want to use bog. How much would it cost roughly to get fixed up?
    wagon
    Nov 2006
    South East Vic
    depends how bad the rust is you might get away with sanding it back the using some rust convertor, or if it needs to be cut out then you can weld a new plate but then youll need bog.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Try giving Rare Spares a call, They have replacement sections for the most common panels that rust out . Failing that as said before weld a new section in then lead wipe it instead of using bog , will last much longer . Removing the whole 1/4 panel is a big job.It is spot welded around the wheel arch ,around the windowand boot.I done a fair few of them when i worked at G.M.H in Dandenong .The section where the roof joins the 1/4 panel is spot welded then lead wiped
    VSClubby355's Avatar
    VSClubby355 is offline EFI Torque
    Apr 2005
    Allcomm wrecking have both left and right new old stock quarters
  1. Rear quarter windows
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 12:18 PM
  2. Replacing Panels (vh wagon)
    By MG's VH Wag in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-10-2007, 07:32 PM
  3. Guards and Quarter panels
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2006, 09:13 PM
  4. Vt Quarter Panels
    By He Digs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2006, 12:02 AM
  5. Both Quarter Panels Vandalised
    By KingDiamond in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:29 PM
