my boot .... it wont open. i changed my locks a while ago to those solex type. & now, randomly i cant open my boot. i put my key in the hole & it doesnt turn at all. ive ripped out the back seats only to discover that the foundation of the back is welded. anybody?
got an angle grinder?
if not get some multi grips and grab the lock and rip it out it will be the only way
ps: solex locks are crap
Solex locks are they like the vending machine ones with a key with like six or so pins on the end if so ive got plans on making a lock picker to pick them with might have worn a bit and the key wont work but you should be able to still pick it open can maybe post it up but would rather email it save putting to many peoples security at risk even though they are on the net allready.
if oyu can pull the back seat out, get a socket on a long extension bar and unso the the striker or a long phillips head and undo the 2 latch retaining screws
if that fails
Try removing a speaker from the parcel shelf and doing the same
if that fails
grab the boot lid either side of the boot lock and pull really hard and force it open, it will break the diecast lcatch but you can replace it, put a VK/VL one in with a electric solenoid. You can fit a trigger cable to it on the inside of the car somewhere hidden if you dont want the electric button for emergency use.
If that fails you didnt pull hard enough, try getting someone who doesnt care about your car to pull on itit has to be really hard.
Else
Try drilling out the lock, make a decisionweather to hack a taillight to pieces or the boot lid, but i have always been able to get into a boot using the above methods. make sure you get a replacement tail light before you hack at oneElse jam a flat blade screw driver int he lock and slot and give it a really good twist, it will bend the toungues off the boot lid and should open the boot.
cheers
Scott
Have you tried putting some graphite into the lock.
kennybear.
I got a VB lock with a VL boot latch, they say all the keys work on all commodores which is BS, my VB's keys wont even open my VC locks same with VC keys on the VB lock.
Take ur speakers out dude on your parcel shelf and see if u can reach the bolts on the boot arms,atleat then u can open one end of the boot up abit to see if theres any issues. if not try removeing the lock with a flathead.
Try a long ass tool ur can stick through the backseat wall and undo the latch screws..
just get a screwdriver in behind the lock and pop it out then stick a screwdriver in there and open it. Solex locks are great apart from the ****ty clips that holds them in if you use them for fck sake make better clips to hold em in
my vl boot didnt open the other day, i pulled it towards me and lifted at the same time, still grabbed but it came open. maybe try that?
I've got solex locks too, never had a problem with them. But i did buy pretty expensive ones that aren't meant to use ****ty metals.
As for your boot problem, i'd just say what most of the people here are saying. Either try to rip out the lock or pry open the boot.
When you manage to do it put a solenoid release in it. I've got 3 ways to open my boot, alarm, solenoid and key. If one fails I've always got something else. Now saying that i bet my solenoid dies and my key doesn't work anymore. :/
"Zooooom"
yeah ... i tried the flathead screwdriver ,one problem... it scratches the paintwork. i have a custom parcel shelf, so my original parcel shelf is welded to the chasis ..i think. i havent got around to the boot yet tho, ive been sooo busy.
^^^^ i think ill do this tho.get a socket on a long extension bar and unso the the striker or a long phillips head and undo the 2 latch retaining screws
but ive been meaning to change my bootlock to the vl solenoid ... but im not 100% sure how to do it. say i see one in the wreckers ,what parts do i need to rip out?
Mines basically a solenoid connected to part of the boot lock. Basically look under the boot around the lock, (left is of it) and theres a solenoid with wire coming off it to latch onto the lock. When it engages it pulls a part of the latch which unlocks the lock. The solenoid is just screwed onto the boot, theres holes for the solenoid screws.
Thats how mines setup, running a wire to gnd and the other side runs through the car to the dash where i've got a switch mounted.
"Zooooom"
sorry to hijack but is there any way to fix my electronic boot release? its not strong enough to pull the boot latch. i know the solenoid works because ive had the boot open and watched it while someone pressed the button..
if i just sprayed the boot latch in WD40 would that loosen it up enough for the solenoid to pull the latch?
thanks..
sounds more like the solenoid is sitting to close and has to much slack on the wire connected to the boot latch.
If the solenoid isn't pulling hard enough and is far enough to keep the wire tight, the coil is probably screwed.
"Zooooom"
