Its pretty straight forward
You can make the change in stages to make it easier and keep the car on the road longer.
I did my pedal box first, I took the dash appart, unbolted the master cylinder & brake booster and swapped over thepedal box.
The gearbox chage is pretty straight forward, remove all the auto components, including the T bar fromt he transmission tunnel, plus the flex plate. Dont forget to install a new spigot bush in the crank shaft and lube it with a small amount of grease. Then basically install all the manual bits.
I cant remember if the tailshaft will fit or not it was nearly 10 years ago i did my conversion.
cheers
Scott
LinkBack URL
About LinkBacks
