looking for some help on plugs for my 308 SLE...i put some
bosch plugs in a few days ago and the gap was 0.9mm...the
place i went to didnt have ngk's in stock ...gregorys manual
says the gap should be 1.5mm ??
what are the best plugs to use in this blue motor? and what
should the gap be?
Personally I run the GMH/AC Delco plugs or Denso plugs. As for gap 1mm is the factory spec VB-VT 5L. I run mine at 1mm.
As for Bosch plugs I bought a set once and got about 200km before they started to break down, my best results have been with the Denso or AC Delco plugs.
cheers
Scott
