Results 1 to 3 of 3
Thread: drive gears - vh
    83 VH slx
    Oct 2006
    Adelaide Sa
    Default drive gears - vh
    ok well i own a vh,
    i had starter problames and went through alot of bullsh*t, and then i was told my ringear was buggered.
    so i rang around, and a mechanic said that auto's dont have ringears? they have drive gears/ drie plates?
    the price from city dismantlers was 440 firm for a new starter and a new ringear.
    price from local mechanic was 340 for a new drive gear ( i think he acctualy said drive plate ). which apparently would solve the problame.
    would appreciate it if somebody could shed some light.. want to get this fixed properly asap. ( get my p's next week.. so i want it running.. )
    any ideas? thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Basically the same thing but a manual has a thicker flywheel so they are called ring gears and the auto has a thin flywheel and the teeth are more of a plate attached to the flywheel. Auto's are dearer to fix yes, try and get hold of a complete s/h flywheel.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The ring gear normally only wears in three places on a 202 and you might be able to get away with undoing the bolts to the crankshaft and turning the flexplate half a turn and then doing the bolts up again so the starter is now engaging on a different position on the ring gear.
  1. what drive "D" do u guys drive in
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2008, 09:45 AM
  2. Dumb question about Drive gears.
    By Stephen_Vn_Exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2007, 09:27 PM
  3. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
  4. T5 speedo drive gears
    By vkberlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2005, 11:04 PM
  5. Speedo drive gears
    Last Post: 02-06-2005, 07:14 PM
