hiya all just wondering will the doors from a vh fit a vb i was told would have to change everything ie guards lights grill true or false
The VH doors will fit the VB no worrys. Who ever told you about the need to change the guards, headlights etc. is about using VH headlights.
if you are changing the vb front end to a vh front end, then you will have to change the grill, lights, front guards and you will have to do a bit of grinding the fit the headlights and indicators in...
But if you just want to change the doors then nothing needs to be changed. The Vh doors will bolt straight on. Hope this helps!
