ey guys
im wondering if i could put vl front side panels, bonet n front vl bodykit to a vk making it half vl n half vk is this possible???
VL's are not completely different from the firewall forward, just slightly different, mainly around the headlight/radiator support.
it can be done as i have actually seen one done before, kinda looked odd though.![]()
anything is possible with time and money!!![]()
if you want a VL just buy one dont wreck the tough VK front end
Yes can be done, you need to change the radiator support over as they are different, front apron included. change the guards, bonnet, lights etc and your good to go.
cheers
scott
thanks for that guys, i thought it would good little project to do, it wouldnt reli cost much as i would get everything from u-pull-it its just a matter of having time to do it.
If your going to do it that way get a front cut through the towers, that way you can unpick the spot welds on the subframe skirts, along the chassis rails & radiator support to make the job look really good.
cheers
Scott
